O2 Sensor going bad...
Old Apr 27, 2005 | 06:39 AM
JDM_SOHC's Avatar
Default O2 Sensor going bad...
I've been having a rough idle problem for a little while, and i've checked all the sensors on the Intake Manifold, and sprayed carb cleaner on all my vacuum lines to check for leaks, still no luck.. Well, I remember a while back I had a 95 turbo eclipse, and I had the same rough idle problem and it was my O2 Sensor, any chance that this is my problem? Thanks...
Old Apr 27, 2005 | 06:41 AM
snatch's Avatar
Default Re: O2 Sensor going bad... (JDM_SOHC)
Any check engine lights?
How many miles on the car?
Old Apr 27, 2005 | 07:17 PM
JDM_SOHC's Avatar
Default Re: O2 Sensor going bad... (******)
no CEL, and i got the motor about 2 months ago with approx 30-50k miles.. JDM D15B.. but i used the o2 sensor off my d15b7 before the swap cuz my jdm motor had all sensors cut... and old motor had 90k...
over-rev
Apr 19, 2006 12:43 PM
Jayboy
13
Jun 19, 2005 12:29 AM
IloveNewt
Mar 24, 2003 12:53 PM
kHoA DoGG
Nov 20, 2002 05:25 PM
