Installing aebs manifold, bypass coolant lines, and removing purge ?'s
Old Apr 26, 2005 | 09:47 PM
Modified Motors's Avatar
Default Installing aebs manifold, bypass coolant lines, and removing purge ?'s
I have a 91 crx hf with a b16a, obd0. I just got my aebs intake manifold, and removed my stock one tonight. I have bought a new pvc valve and manifold gasket. I also bypassed the coolant lines going to the tb and iacv.
I am planning on removing my evap purge control, and was wondering Now can I just remove the vaccum lines going to it, and just leave it plugged in to the harness. What are the cons of removing the vaccum lines to this? The only reason I want to do this is to get rid of the clutter of lines. So basically I will have vaccum lines for my fpr, map sensor, pvc, brake booster, and charc. canister. Any info would be great, as I am instally my manifold tomorrow.
Old Apr 27, 2005 | 11:09 AM
Default Re: Installing aebs manifold, bypass coolant lines, and removing purge ?'s (Modified Motors)
bump about to install
jdmwojo
Jan 31, 2010 10:07 PM
kyle-Lst
16
May 8, 2007 10:00 AM
d_SUPAl1l
Nov 21, 2006 07:39 PM
Pandahatch
Jan 29, 2005 11:02 AM
Tuney
Feb 26, 2003 07:19 PM
