Vtec controller with check engine light
I have installed a vtec controller but when I accelerate at a slow rate and Vtec comes on my CEL comes on with the Vtec code. If i accelerate fast and go through the gears i have no problem, but if i am cruising in lets say 3rd at 35 mph and i hit the gas and let vtec come on with my rpm slowly climbing my CEL will come on and its always the same vtec code. I have pretty much concluded that if vtec is on for an extended length of time thats when it throws the code. I know it is wired correctly, i have already replaced the filter in the solenoid and i change my oil regularly. Any suggestions?
uhh, try check your oil level? i remember when my CEL turned on once, it was because the vtec selenoid deteced low oil preassure?
if that isnt it then sorry buddy im dead with thoughts.
Pr0ject93hb
Sep 14, 2007 09:50 AM
