Air/Fuel Gauge responding slowly
Old Apr 26, 2005 | 03:41 PM
wrEcKed_LX's Avatar
Default Air/Fuel Gauge responding slowly
I read an article today about a gauge install and it was talking about how the gauge was responding slowly. They knew to replace the O2 sensor and it was moving normally. How are you to know if the gauge is responding too slowly? I remember a prelude that had an air fuel gauge in and it seemed to respond quickly, while i was in a hatch yesterday and it was moving very fast back and forth. What could be wrong? Or is it normal for it to respond slowly in a single cam civic? I really feel like a retard asking this kind of question...
Old Apr 26, 2005 | 03:45 PM
Luserkid's Avatar
Default Re: Air/Fuel Gauge responding slowly (spoon_ferio)
No Wideband, no accurate responce.
Its just a dancing light show.
pgpunkguy's Avatar
you're talking about narrowband o2 sensors...
when very lean, they show lean...
when very rich, they show rich...
when somewhere in between, the oscillate back and forth...
if it behaves otherwise, the sensor may be bad or there may be a bad connection between the gauge and sensor
Old Apr 26, 2005 | 03:51 PM
wrEcKed_LX's Avatar
Default Re: Air/Fuel Gauge responding slowly (pgpunkguy)
I know wideband O2's are much better and actually work as opposed to normal ones. It does move back and forth between rich and lean just not very much; and if it does, it does so fairly slowly.
Old Apr 26, 2005 | 03:56 PM
pgpunkguy's Avatar
double check your connections behind the gauge... you might not have a good ground, or you might have a bad connection to the o2 sensor
rohec04
May 26, 2009 11:34 AM
ballinthavx
Oct 23, 2005 11:56 AM
mehdiR
Aug 23, 2005 07:32 AM
MugenPoweredLude
Dec 29, 2002 12:18 AM
