Bogging issue...help please...
Here's my setup:
92 Cx hatch w/d16a6 (it's all I could find at the time)
z6 wire harness, z6 intake manifold, y7 distributor, p06 ecu
Here's my problem:
It runs alright driving around town, but when I'm at a steady speed on the highway for a couple mins, the sucker bogs down on me and doesn't want to go anywhere. I have to pull over and the shut it off for a min or so. When I start it back up, it runs ok again. But it keeps doing this over and over. No check engine light yet. I heard that a map sensor could act up without a CEL, is this true? And can an ignitor cause this bogging also? I heard that the 96+ distributor's had a recall from Honda because of bad ignitors. Please help, my daily driver is kinda out of commission right now.
Here's my problem:
you head gasket is going to shyt... I had the same problem and It was because the gasket had a small leak and it would drown my plugs.. I changed everything from distibutor, to plugs, wires, injectors, etc.. Damn head gasket leak...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harassing Herbs »</TD></TR><TR><TD CLASS="quote">what are you running as fuel management?
did you check your spark plugs yet?
the condition of the plug could give u an idication of whats going on .</TD></TR></TABLE>
i would guess he is running a stock ecu for the stock motor. I would go with fuel pump or headgasket like the others have stated.
do a leakdown test to confirm that it isn't your headgasket as stated above.
check your ECU for any stored codes.
when was the last tune-up?fuel filter specifically.
get a shop manual and start testing the specs on sensors.
Chris
Chris
I'm getting the same problem at low rpms, 3-5k , theres some bogging/hesitation going on. I'm running almost the exact same setup only i have a chipped p28. any suggestions? I'm going to get dirty this weekend and look more into it, its bugging the **** outa me.
scald24
14
Apr 23, 2007 06:39 PM
EKB18BPR3
Jun 10, 2004 06:18 PM
