idle problem
Old Apr 26, 2005 | 08:47 AM
stoopid_monkey's Avatar
Default idle problem
The rpm sometimes moves down and up. I set the idle a little higher so the car wouldnt turn off. I had the problem check and no one knows the solution. I'm thinking after the timing belt change, the idle been acting up. help plz.
Old Apr 26, 2005 | 09:28 AM
Bond's Avatar
Default Re: idle problem (stoopid_monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stoopid_monkey &raquo;</TD></TR><TR><TD CLASS="quote">The rpm sometimes moves down and up. I set the idle a little higher so the car wouldnt turn off. I had the problem check and no one knows the solution. I'm thinking after the timing belt change, the idle been acting up. help plz.</TD></TR></TABLE>
I have a similar problem. After my TB, water pump and dizzy change my car has been surging at warm up and idle is rough. I checked the timing and it is dead on. Maybe chack your timing. It might help.
Old Apr 26, 2005 | 11:22 PM
Default Re: idle problem (Bond)
ok thanks
ill update if it works or not
whitterjohn
Feb 26, 2009 11:26 AM
PremiumPrelude
Mar 23, 2008 03:45 PM
mouab18c1
Aug 25, 2007 12:46 AM
gooberwolf
Aug 6, 2003 01:59 PM
REDBARON
Oct 4, 2001 07:40 PM
