lsd wont dis-engage
Old Apr 26, 2005 | 04:51 AM
slow91crx's Avatar
Default lsd wont dis-engage
my lsd on my trans wont dis engage after i ran at the track on sunday. i tried launching in reverse and going in tight circles in reverse and its still stuck on. its an integra xsi trans and i think its a stock lsd. thanks for any ideas on how to get this thing fixed
Old Apr 26, 2005 | 01:44 PM
CRseXy's Avatar
Default Re: lsd wont dis-engage (slow91crx)
ha, try launching it agian? I dont know. how exactly do you know its not disengaging???
Old Apr 26, 2005 | 02:21 PM
MtnCRX's Avatar
Default Re: lsd wont dis-engage (pogiTSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI &raquo;</TD></TR><TR><TD CLASS="quote">ha, try launching it agian? I dont know. how exactly do you know its not disengaging???</TD></TR></TABLE>
yeah.. i dont really get the problem
Old Apr 26, 2005 | 03:26 PM
CRseXy's Avatar
Default Re: lsd wont dis-engage (MtnCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MtnCRX &raquo;</TD></TR><TR><TD CLASS="quote">yeah.. i dont really get the problem</TD></TR></TABLE>
I would think if its not disengaging. on tight turns the wheels will skip.
Old Apr 26, 2005 | 03:57 PM
bagpipe goatee's Avatar
how's the fluid in there? if you can't get it to disengage, maybe change the fluid or something.
Old Apr 26, 2005 | 04:02 PM
HamiltonRex's Avatar
Default Re: (bagpipe goatee)
are these things supposed to disengage? WTF?
Old Apr 26, 2005 | 04:29 PM
user 98292739's Avatar
yea? i thought the purpose of a LSD let both tires spin at the same rate..and not have one spin by itself?
Old Apr 26, 2005 | 04:58 PM
tur3oDC4's Avatar
Default Re: (LoCoReX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoCoReX &raquo;</TD></TR><TR><TD CLASS="quote">let both tires spin at the same rate..and not have one spin by itself?</TD></TR></TABLE> thats posi lol
Old Apr 26, 2005 | 06:37 PM
MtnCRX's Avatar
Default Re: (whitepoweredlsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitepoweredlsvtec &raquo;</TD></TR><TR><TD CLASS="quote"> thats posi lol</TD></TR></TABLE>
lsd does the same thing. In turns, it senses which tire has more grip and puts more of the power ot that one. But also off the line, both tires will spin instead of being a one legger.
Old Apr 26, 2005 | 11:14 PM
tur3oDC4's Avatar
Default Re: (MtnCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MtnCRX &raquo;</TD></TR><TR><TD CLASS="quote">lsd does the same thing.</TD></TR></TABLE>I'am not going to go into this ...posi and LSD are not the same.
Old Apr 26, 2005 | 11:29 PM
JonGP4's Avatar
try doing some figure 8s in a parking lot..
Old Apr 27, 2005 | 04:31 AM
ServiceAdvisor's Avatar
Nobody has asked yet WHICH lsd you have. Is it a clutch type or box style? I think we might need alittle more info. What trans also, - Darrell
Old Apr 27, 2005 | 04:36 AM
slow91crx's Avatar
Default Re: (JonGP4)
lsd just means limited slip differential. not locked differential. it lets one tire have more power at some times . if it is locked it will pull back and forth at higgway speeds and kinda skip in corners a tiny bit. and if you put a lsd car on a lift and put it in gear only one wheel will turn. while if its locked both will turn. my car is now " locked " i tried tranny fluid last night but pullin it out of the shop i blew a main under hood fuse and it keeps blowing.. bad news . screw drag racing. car was perfect for years till i drag race it. .
Old Apr 27, 2005 | 05:30 AM
slow91crx's Avatar
Default Re: (slow91crx)
i don't know which type it is. i need to tear into it this week.
Old Apr 27, 2005 | 09:34 AM
MtnCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx &raquo;</TD></TR><TR><TD CLASS="quote">lsd just means limited slip differential. not locked differential. it lets one tire have more power at some times . if it is locked it will pull back and forth at higgway speeds and kinda skip in corners a tiny bit. and if you put a lsd car on a lift and put it in gear only one wheel will turn. while if its locked both will turn. my car is now " locked " i tried tranny fluid last night but pullin it out of the shop i blew a main under hood fuse and it keeps blowing.. bad news . screw drag racing. car was perfect for years till i drag race it. . </TD></TR></TABLE>
ok. i was wrong. i can admit it
Old Apr 29, 2005 | 04:33 AM
slow91crx's Avatar
its cool mtnCRX. most other people are wrong about it too. i don't know if it is really that bad. it is really touchy steering, when you steer one way it pulls you that way and if you counter steer it will pull you the way you steer again, kinda dangerous at times, but sorta fun my crx drifts/drags *** really really easy now. im hoping it doesn't go out cuz it whines a little already. im hoping for the best.
.Ryan
12
Apr 3, 2005 06:57 PM
TATTOO420
Mar 7, 2005 09:18 AM
7speed
Feb 17, 2005 08:17 PM
RI_TM
Jun 30, 2004 02:26 PM
Turbo'dMex-A-Keen
14
May 28, 2004 12:55 PM
