friends minime runs like shit
Old Apr 25, 2005 | 09:46 PM
SpecialGoodness's Avatar
Default friends minime runs like ****
ok we just got this running and it aint too hot. he ligned the timing marks on the cam gear level with the head and lined up the timing mark on the crank pully with the timing cover marks. when he drove it, it had no power under acceleration, and the intake was noticably louder than normal, running rich, valve train noise, and a bad idle.
d15b2
y8 head
y8 cam gear
y8 timing belt
should we put the d15b2 cam gear on the y8 head?
Old Apr 25, 2005 | 09:49 PM
2kTeg's Avatar
Default Re: friends minime runs like **** (SpecialGoodness)
any codes?
Old Apr 25, 2005 | 09:57 PM
SiR Inspired ED7's Avatar
check ur sparkplug firing order
Old Apr 25, 2005 | 10:02 PM
FOMULA91's Avatar
Default Re: friends minime runs like **** (2kTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kTeg &raquo;</TD></TR><TR><TD CLASS="quote">any codes?</TD></TR></TABLE>
Old Apr 25, 2005 | 10:17 PM
doublethink's Avatar
how did the mpfi wiring go?
use a timing light. if you have no codes, its gotta be a timing problem.
spark plug firing order would be a good thing to check as well.
Old Apr 25, 2005 | 11:09 PM
hahagasdcrx's Avatar
Default Re: friends minime runs like **** (doublethink)
Shouldn't the mark on the cam gear ( 8 o'clock position ) be match to the pointer.
Set to the one on the right in the pic.
borrowed pic.
Old Apr 25, 2005 | 11:22 PM
hybrid1990crx's Avatar
The MPFI wiring went fine, he did it before with the stock head and it was fine. he isnt throwing any codes either. he says the firing order is right also. i seem to think its still in the valve timing.
Old Apr 26, 2005 | 04:56 AM
92integra_gs's Avatar
i thinks its either timing or a vacuum leak... or I/M gasket leak... is the idle high?
Old Apr 26, 2005 | 08:29 AM
senpai's Avatar
you didn't adjust the valves?
I suggest an adjustable cam gear as well.
Old Apr 26, 2005 | 08:42 AM
thenick's Avatar
Default Re: friends minime runs like **** (senpai)
I'm willing to bet the timing belt is off a tooth.
Old Apr 26, 2005 | 09:25 AM
Bjorn20's Avatar
kind of a dumb question for ya... what is a minimi?? ive seen that in like 20 different threads but i dunno what it is... so ya, someone explain?
Old Apr 26, 2005 | 10:16 AM
Its me DUB's Avatar
Default Re: friends minime runs like **** (Bjorn20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote">kind of a dumb question for ya... what is a minimi?? ive seen that in like 20 different threads but i dunno what it is... so ya, someone explain?</TD></TR></TABLE> the search button top right of the page will tell you all you need to know
Old Apr 26, 2005 | 11:00 AM
user 98292739's Avatar
hmmm my car runs fine but seems lower after the mini me....the timing TO ME seems lined up perfectly..ignitino timeing is at factory setting. how would i know if im off a tooth? sorry for the thread hi jack but seems related
Old Apr 26, 2005 | 11:36 AM
doubleA's Avatar
Default Re: (LoCoReX)
you would know if the timing belt is off a tooth if you took a 17mm wrench put it on the crankpully and turned untill you saw the TDC mark line up to the sights on the timing belt cover. Than check if your marks line up on the cam gear. Are you guys using a timing light on these??
should we put the d15b2 cam gear on the y8 head? --- I think this would be a bad idea. I believe the y8 cam gear is off 1/2 tooth from all other Dseries.
Old Apr 26, 2005 | 11:41 AM
thenick's Avatar
Default Re: (doubleA)
Out of curiousity, was the head milled at all?
Old Apr 26, 2005 | 11:44 AM
doubleA's Avatar
Default Re: (thenick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">Out of curiousity, was the head milled at all?</TD></TR></TABLE>
This is where the ajustable cam gear comes into play. ^^^
Old Apr 26, 2005 | 12:14 PM
vegaskurt's Avatar
unless you had an adjustable cam gear you will be off by half a tooth in either direction. d15 deck height is different than the d16's. get a timing light to see where you are at.
thatseemslegit
42
Sep 17, 2015 09:07 PM
EARLdaSQUIRREL
May 7, 2009 02:14 PM
xsenceo89x
Dec 27, 2007 11:45 AM
freakasis
Jan 2, 2006 12:18 PM
