crx backwards idle
Old Apr 25, 2005 | 08:39 PM
crx90rcr's Avatar
Default crx backwards idle
well i start my car every morning and everyday i look down and my idles at 250 pisses me off so much . well the weird thing is the more heated up the car is the higher idle i have like operating temp it will idle at like 1250 but cold it is still at like 250 i dont get it well im looking 4 any ideas and my setup is d15b2 with mpfi swap and si cam cai header and basicly stock exhaust
Old Apr 25, 2005 | 09:34 PM
bagpipe goatee's Avatar
maybe your fast idle thermo valve is messed up, i might have the name wrong, but there would be that, that controls the idle before its warm, and then after it warms, the iacv takes over.
Old Apr 25, 2005 | 11:33 PM
Mr_CRX's Avatar
Default Re: crx backwards idle (crx90rcr)
I had a similar problem. I replaced the IACV, and it fixed it.
but, also check your FITV. Make sure all the pieces inside are all screwed together. They ahve a tendency to work loose over the years.
Old Apr 26, 2005 | 12:39 AM
hahagasdcrx's Avatar
Default Re: crx backwards idle (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problem. I replaced the IACV, and it fixed it.
but, also check your FITV. Make sure all the pieces inside are all screwed together. They ahve a tendency to work loose over the years.</TD></TR></TABLE>
Bad IACV or not plugged in. Might have the wrong plug on there since there is one extra when doing a dpfi-mpfi swap.
Old Apr 26, 2005 | 08:16 PM
crx90rcr's Avatar
Default Re: crx backwards idle (hahagasdcrx)
i dont have a fast idle sensor and those wires are just cut off i just thought of this but what if i solder them together could that make it a more even idle or by a resistor type thing well any other idea are apretiated
Zee.I
Jul 11, 2021 11:36 PM
TegraD
Aug 20, 2008 04:49 PM
LukieLuc
Sep 19, 2007 07:37 PM
kihun_cha
25
Aug 5, 2004 09:49 PM
Br1anPham
Feb 2, 2004 05:29 PM
