Catch Can off Valve cover??
hey guys ive seen a lot of this on HT now and i was just woundering if someone could explane what it does/ the benifits of doing it ...thanks
I was told that it keeps oil from getting in the engine bay, but not really sure how it works. Hopefully someone will chime in with a valuable answer.
simple search for "catch can"
two results here,many more to be had:
https://honda-tech.com/zerothread?id=1216548
https://honda-tech.com/zerothread?id=1188759
Chris
Chris
A catch can, primarilly used on boosted applications (but not uinheard of on an NA application by any means), is used to releave pressure under the valve cover. In doing so, it "catches" oil that would normally be forced out around seals in the can for which it is named. The oil/sludge is trapped in the can and the air is fed back into the valve cover/manifold area.
That's a rudimentary definition. You can learn more via searching. I don't do a lot of boosting, myself (NA **** here), but it's a start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox »</TD></TR><TR><TD CLASS="quote">where can i get one of those oil filter relocation kits?
yea that too
yea that too
aleks77
Nov 10, 2022 01:51 PM
