Passanger door lock is buggered...
Old Jan 31, 2002 | 06:20 PM
Cryptopsy's Avatar
Default Passanger door lock is buggered...
Ok, just for no particular reason, the passenger door lock stops working. Like, I try to put the key in to unlock it, but it just turns and wont unlock. I have to get into my side first and unlock it from the inside.
Its buggered right? Ahhhh sh|T thats what I though. How hard is this to fix? Anybody else got this problem?
Oh ya, whats the best air intake to buy? JUST KIDDING!
Old Jan 31, 2002 | 06:39 PM
Louie B.'s Avatar
Default Re: Passanger door lock is buggered... (SoulflyCRXsi)
you probably lost the little rod conecting the key cylinder and the latch mechanism... you should be able to see the problem by removing your door panels
Old Feb 1, 2002 | 06:12 AM
Superhatch's Avatar
Ive never fixed the problem personally...but if you take of the door panel you should be able to see the problem pretty clearly.
Good luck.
Old Feb 1, 2002 | 06:17 AM
PatEJ6's Avatar
Default Re: Passanger door lock is buggered... (SuperHatch)
yep
blacktibby07
Feb 5, 2011 06:37 AM
J.WOLFE~v1.0
Dec 23, 2010 04:23 PM
01PYTypeR#1140
Apr 29, 2002 03:36 PM
E Swift
Oct 25, 2001 03:37 PM
