where can i get k20a2 head?
title is pretty self explanitory. im looking for just the head, because i want to do a head swap. i currently have the a3. i have found the entire k20a2 engine, but i just want the head. from what i head its a simple bolt on procedure. yes, i would need the k-pro upgrade and a higher quality head gasket, but thats fine. i guess the other thing i want to know, i that if i do this head swap....does that mean i will have to take my rev hard turbo out? will i have to remove anything at all? or can i just be lucky for once and just swap heads, get the k-pro upgrade and be on my way? i am looking for a new head, but if anyone has a used one in good condition, that might work too.
im not super familiar with the TSX engine. what are the specs on the head? is it as easy of an install as the a2 head swap? because the a2 is is basically just bolting that sucker right on to the existing connections.
itrs pretty much a bolt on deal, but if you want to use a type S or R intake manifold, there is one modification you have to do to a water port. search some sites like EPHATCH or CLUBRSX...there are people there that have already done this.
92hatchdude
Nov 10, 2003 09:10 AM
