How high do you rev your ITR on a track?
Old Apr 25, 2005 | 08:27 AM
petrv's Avatar
Default How high do you rev your ITR on a track?
I already know that ITR's are very reliable when used on a race circuit. How high do you rev your ITR on the track? Can I go all the way to the rev limiter in each gear? Or do you rev your ITR a bit lower just to be safe?
My current reving on a track is evident from this video from our local track: http://www.veit.cz/video/itr_track.avi
Old Apr 25, 2005 | 08:32 AM
Bbasso's Avatar
Default Re: How high do you rev your ITR on a track? (petrv)
I wail it, Hard.
Old Apr 25, 2005 | 08:34 AM
Nuts's Avatar
Default Re: How high do you rev your ITR on a track? (Bbasso)
<- rev limiter every gear.
92TypeR's Avatar
FSAE
I try to keep revvs under 8200ish, just precautionary.
However, if I have to stretch the gear in a corner, I have full confidence in shifting at redline.
R blocks are very stout and can handle 9000 no problems. As long as you keep your oiling system working I don't see why you should stay away from redline.
Old Apr 25, 2005 | 09:10 AM
Pompiuses's Avatar
I usually rev it to redline at 8500. Knowing that the tach is a bit off in most ITRs, real rpm would be around 8100.
Old Apr 25, 2005 | 09:53 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: How high do you rev your ITR on a track? (Pompiuses)
As noted above, there is some tachometer error. And, when you've got the accelerator to the floor, the revs are climbing pretty fast, so it's not uncommon to be off by a couple hundred RPM from where you're trying to shift.
I try to shift at redline (8400 RPM indicated on the tachometer, whatever the actual RPMs are), in every gear, whenever accelerating.
I don't let it hit the rev limiter. Not intentionally, anyway. That would upset the balance of the car too dramatically (same thing as suddenly lifting off the accelerator).
Old Apr 25, 2005 | 09:59 AM
Big Phat R's Avatar
I go to about 8K most of the time.
Going any higher just increases the risk of something ******* up and really doesn't make the car go that much faster
Old Apr 25, 2005 | 10:06 AM
dandc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">I wail it, Hard.</TD></TR></TABLE>
ditto
Old Apr 25, 2005 | 10:19 AM
madP's Avatar
iam always riding on the rev limiter witch is set a tad higher 9600rpm but my car is far from stock its turboed and iam currently runing 403 whp these car are meant to be rided hard...
Old Apr 25, 2005 | 11:22 AM
uNF$@#!'s Avatar
once your good enough, you too can be like takumi and have a 8500 redline but force yourself to keep it under 6000 rpms
Old Apr 25, 2005 | 11:28 AM
fastfour's Avatar
9100rpm. B16b is a beautiful thing
Old Apr 25, 2005 | 12:45 PM
itr1244's Avatar
what's your setup? car looks pretty quick
Old Apr 25, 2005 | 01:09 PM
Viper8L488's Avatar
it's the only way to go.
Old Apr 25, 2005 | 01:14 PM
Im_In_There's Avatar
Default Re: How high do you rev your ITR on a track? (Viper8L488)
Till fuel cut off!
Old Apr 25, 2005 | 01:56 PM
Azcheron's Avatar
Default Re: How high do you rev your ITR on a track? (Im_In_There)
ill be wailing it right to 9000 WITH the super charger at 9 psi, lol
Old Apr 25, 2005 | 02:09 PM
Dirt's Avatar
2 Saturdays ago at Gingerman, I kept it in 3rd gear going into T1. 9000 rpm indicated (or VERY close to the fuel cut of 8650). I only fuel cutted twice. More importantly, zero oil consumption. Most importantly, no parts came flying out of the engine bay.
Old Apr 25, 2005 | 02:24 PM
d.n.d.'s Avatar
Default Re: How high do you rev your ITR on a track? (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">once your good enough, you too can be like takumi and have a 8500 redline but force yourself to keep it under 6000 rpms </TD></TR></TABLE>
LOL haha more like 10,000 redline and kept at 9000rpm btw u watch the 2 newest ID episodes?
Razr2
15
Jan 1, 2008 10:24 PM
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
MOVE OVER
Mar 12, 2005 02:12 PM
2slo4me
Jun 23, 2003 11:22 AM
JDM97R
Dec 16, 2002 11:56 AM
