The Death of a B18C **PICS**
Old Apr 25, 2005 | 07:51 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
Default The Death of a B18C **PICS**
went to an open track day yesterday, here are the results........
Old Apr 25, 2005 | 07:52 AM
kadburry's Avatar
Default Re: The Death of a B18C **PICS** (BrokeAssWhiteboy)
damn that sucks!
Old Apr 25, 2005 | 07:53 AM
b204dr's Avatar
that valve bitch slapped that piston!
Old Apr 25, 2005 | 07:54 AM
BauleyCivic's Avatar
Risky Business
Default Re: (b204dr)
Good work
This is why I will never spend $3000 on a motor
Go SOHC!
Old Apr 25, 2005 | 08:01 AM
VALET dude's Avatar
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Good work
Go SOHC!</TD></TR></TABLE>
^ what a response . anyways, condolence to the mota, time to build another one. keep us updated.
Old Apr 25, 2005 | 08:05 AM
b204dr's Avatar
Default Re: (JDMallmotaEG)
He's a D Ninja ! he spites b series while others need more potential!
Old Apr 25, 2005 | 08:06 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallmotaEG &raquo;</TD></TR><TR><TD CLASS="quote">
^ what a response </TD></TR></TABLE>
You're just jealous that when my motor blows I pay $200 for a new one
Old Apr 25, 2005 | 08:08 AM
SkRiBLaH's Avatar
not a total loss thank god.
you can still save the head and re-sleeve the bock.
back in action after about $1000-1300
Old Apr 25, 2005 | 08:09 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (SkRiBLaH)
So what are you going to do now?
You're just jealous that when my motor blows I pay $200 for a new one</TD></TR></TABLE>Amen brother.
Old Apr 25, 2005 | 08:12 AM
b204dr's Avatar
are you stock internalled - ?
question for gsr with the valve problem what where you running to cause this - did you need a major valve adjustment or what-! over rev?
Old Apr 25, 2005 | 08:15 AM
DBLAZE's Avatar
WOW....That's like the worst pic of the inside of a motor I have ever seen... Not too bad though...could be fix-able.....it just sux that you gotta pay to fix it....
Old Apr 25, 2005 | 08:37 AM
clint g's Avatar
Default Re: (DBLAZE)
good luck with that
Old Apr 25, 2005 | 08:39 AM
FasteddieIX's Avatar
Oof. That sucks. Good luck finding a new one.
Old Apr 25, 2005 | 08:42 AM
DxBurnoutKing's Avatar
****** word!
D-Series fo lyfe
Old Apr 25, 2005 | 08:43 AM
slo97coupe's Avatar
**** THE BED that suksman... danm im bout to get a b18cR my self tell me what happend and what ur gona do??!!
Old Apr 25, 2005 | 08:46 AM
jg-hatch's Avatar
Default Re: (ek97-DAP)
OUCH!!!!!!!!!!!
Old Apr 25, 2005 | 08:53 AM
ralphie14's Avatar
Default Re: (jg-hatch)
I would also be really interested in what caused this. Over rev, needed adjustment, faluty install of new parts, were you NA or running boost ect. Let us know becuase that is some carnage there.
Old Apr 25, 2005 | 09:04 AM
Soccerking3000's Avatar
Default Re: (ralphie14)
dude you have a little oil in your coolant, you should check that out...
Old Apr 25, 2005 | 09:16 AM
pinoyrukus's Avatar
OMG O_o
that suxs
Old Apr 25, 2005 | 09:22 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: The Death of a B18C **PICS** (pinoyrukus)
Can we get a little more info? the pics are cool but I'd like to see some more tech.
Old Apr 25, 2005 | 09:35 AM
xtremecivichb's Avatar
this photo was snapped one turn before the engine let loose,
the car was n/a jdm type r pistons, .25 over, jdm itr intake cam, motor was rebuilt in november the head was all stock with well over 250,000 miles on it
. the damage happened on a 2-3 shift i didn't over rev it, the car has hondata with the full throttle shift feature,
it went into third and pulled for a second then let loose
the plan for now is to boost the gsr engine i have had sitting on a pallet for the last couple of weeks,
and plan to be back out for the next high speed touring event in may
Old Apr 25, 2005 | 09:37 AM
^^^that was me i forgot to log the boss out
Archidictus's Avatar
Unceasing Measure
So it just went, eh? That blows. Good luck on the rebuild .
Old Apr 25, 2005 | 09:42 AM
b204dr's Avatar
i think the oil in his coolant is meerly from when he removed his head- it dosnt look mixed with the coolant - surely isnt detonation - the neighboring piston does look chared a little bit but i bet this one would be the same if the valve didnt make contacts and put a whole in the piston- remove the piston check the cylinder walls how scared they are- see if the rod is bent - if the rod is fine just buy some new pistons- if the rod is bent - upgrade all new rod & pistons - all depending on budget- but more info - i like seeing what the cause for painful looking engine damage- always think it could have been worse and kicked a hole in your block!
Old Apr 25, 2005 | 09:43 AM
.BigSexy's Avatar
most hood white kid
SOHC 4 life brother
