The Death of a B18C **PICS**
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Good work
This is why I will never spend $3000 on a motor
Go SOHC!</TD></TR></TABLE>
^ what a response . anyways, condolence to the mota, time to build another one. keep us updated.
Risky Business
Re: (JDMallmotaEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallmotaEG »</TD></TR><TR><TD CLASS="quote">
^ what a response </TD></TR></TABLE>
You're just jealous that when my motor blows I pay $200 for a new one
I am a (Trial User) Army
Re: (SkRiBLaH)
So what are you going to do now?
You're just jealous that when my motor blows I pay $200 for a new one</TD></TR></TABLE>Amen brother.
Re: (BauleyCivic)
are you stock internalled - ?
question for gsr with the valve problem what where you running to cause this - did you need a major valve adjustment or what-! over rev?
Re: (b204dr)
WOW....That's like the worst pic of the inside of a motor I have ever seen... Not too bad though...could be fix-able.....it just sux that you gotta pay to fix it....
Re: (BauleyCivic)
****** word!
D-Series fo lyfe
****** word!
D-Series fo lyfe
Re: (jg-hatch)
I would also be really interested in what caused this. Over rev, needed adjustment, faluty install of new parts, were you NA or running boost ect. Let us know becuase that is some carnage there.
Re: The Death of a B18C **PICS** (BrokeAssWhiteboy)
this photo was snapped one turn before the engine let loose,
the car was n/a jdm type r pistons, .25 over, jdm itr intake cam, motor was rebuilt in november the head was all stock with well over 250,000 miles on it
. the damage happened on a 2-3 shift i didn't over rev it, the car has hondata with the full throttle shift feature,
it went into third and pulled for a second then let loose
the plan for now is to boost the gsr engine i have had sitting on a pallet for the last couple of weeks,
and plan to be back out for the next high speed touring event in may
i think the oil in his coolant is meerly from when he removed his head- it dosnt look mixed with the coolant - surely isnt detonation - the neighboring piston does look chared a little bit but i bet this one would be the same if the valve didnt make contacts and put a whole in the piston- remove the piston check the cylinder walls how scared they are- see if the rod is bent - if the rod is fine just buy some new pistons- if the rod is bent - upgrade all new rod & pistons - all depending on budget- but more info - i like seeing what the cause for painful looking engine damage- always think it could have been worse and kicked a hole in your block!
most hood white kid
Re: (BauleyCivic)
SOHC 4 life brother
SOHC 4 life brother
