d16y8 swap in obd 1
Old Apr 25, 2005 | 07:42 AM
POE's Avatar
POE
Default d16y8 swap in obd 1
i know this info. has been covered. im searching right now for all my answer's. I cant find the exact answers im lookin for though..
OK, so my girlfriend bought a 92 civic dx, it has a d15b7 and the rings are ****, it smokes, I found a d16y8 for 200 bucks from a local buddy. i know its obd 2 and i have an obd 1 car, Would i be able to use my stock obd 1 engine bay harness or will i need to convert the whole thing over to obd 2, also do i need to get a obd1> obd2 conversion wiring harness for the ecu? and i will need to run the d16y8 ex ecu?
im sorry, i know this has been covered. i just can seem to find all the exact info im looking for, if u have any use full links please post them. thanks again.
Old Apr 25, 2005 | 07:54 AM
BauleyCivic's Avatar
Risky Business
Default Re: d16y8 swap in obd 1 (POE)
Run the B7 distributor, and P28...run the wires for VTEC. It should be just fine. If you have problems with the injectors, just use the B7 intake manifold/injectors.
Old Apr 25, 2005 | 08:03 AM
POE's Avatar
POE
thanks dustin, what about the sensor's that are on the d16y8 , and the d15b7 dont have,
For example, the d15b7 has a FITV, and the d16y8 doesnt, or in its place there is a sensor...
Old Apr 25, 2005 | 08:28 AM
POE's Avatar
POE
im just gonna use the d15b7 manifold,
Anyone know what i should do about the knock sensor on the d16y8?
just not hook it up?
Old Apr 25, 2005 | 09:44 AM
POE's Avatar
POE
ttt
Old Apr 25, 2005 | 10:31 AM
POE's Avatar
POE
Old Apr 25, 2005 | 10:38 AM
shiftgear8000's Avatar
Default Re: (POE)
use the y8 manifold, and the d7 injectors.....
you won't have to wire the knock sensor, just use a p28 from a 92-95 ex/si...it's a single cam vtec, but doesn't have a knock sensor to wire up, so it won't look for one.
also, if you could find the wiring harness for a 92-95 ex/si that will help make the wiring a lil' easier for ya.
Old Apr 25, 2005 | 10:49 AM
POE's Avatar
POE
its allready wired for vtec, what about the FITV? there isn't one on a d16y8 but there is on d15b7...
Old Apr 25, 2005 | 07:25 PM
POE's Avatar
POE
Default Re: (POE)
ttt
Old Apr 26, 2005 | 10:27 AM
Otherguy's Avatar
NASIOC.com
Default Re: (POE)
dont worry about it =D
Old Apr 26, 2005 | 10:30 AM
POE's Avatar
POE
is that all u have to say?
Old Apr 26, 2005 | 11:52 PM
Otherguy's Avatar
NASIOC.com
Default Re: (POE)
yes it is
Old Apr 27, 2005 | 01:00 AM
96-EJ6 B18C's Avatar
Default Re: (POE)
Basically if the sensor isn't on the OBDI motor then the OBDI ecu won't be looking for it, don't hook it up, no code no problem. There is no knock on a P28 so don't worry about that either.
Old Apr 27, 2005 | 06:35 AM
Otherguy's Avatar
NASIOC.com
Default Re: (96-EJ6 B18C)
see told yah =P
Old Apr 27, 2005 | 08:41 PM
Default Re: (Otherguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">see told yah =P</TD></TR></TABLE>
LOL
Old Apr 28, 2005 | 10:20 AM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">
LOL</TD></TR></TABLE>
u are gay my friend.
Old Apr 29, 2005 | 01:52 AM
Default Re: (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">
u are gay my friend.</TD></TR></TABLE>
I'm the one giving the (correct) advise, not asking the stupid question...
So if that makes me gay, then whatever :rolls eyes:
Old Apr 29, 2005 | 09:58 AM
POE's Avatar
POE
So if that makes me gay, then whatever :rolls eyes:</TD></TR></TABLE>
im sorry, im talking about that *** that said "SEE TOLD YA" and then u laughing at what he said. i Though that dude's comment was so ******* retarded. so i called u gay for lauging at him.
Old Apr 29, 2005 | 10:58 AM
Otherguy's Avatar
NASIOC.com
Default Re: (POE)
well im not gay you just didnt listen to what i had to ******* say so shut up and dont call him gay, if anyone it should be me your calling gay.... But then again your the one who should of searched....
Old Apr 29, 2005 | 11:01 AM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">well im not gay you just didnt listen to what i had to ******* say so shut up and dont call him gay, if anyone it should be me your calling gay.... But then again your the one who should of searched....</TD></TR></TABLE>
ha
Old Apr 29, 2005 | 11:59 AM
topREV's Avatar
well i have the same thing as ur saying, i have a 93 hatch with a d16y8 too, i use a p28 and a 95 ex hardness, i use the y8 injector, rewire the y8 injector with the 95 ex hardness injector and just wire the vtec wire to ur ecu, and dont worry about the sensor, for my it run pretty good in the 1/4 miles, did a 14.7, if i have some pics ill post them up too.
Old Apr 29, 2005 | 12:06 PM
POE's Avatar
POE
Default Re: (RPM_EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPM_EG6 &raquo;</TD></TR><TR><TD CLASS="quote">well i have the same thing as ur saying, i have a 93 hatch with a d16y8 too, i use a p28 and a 95 ex hardness, i use the y8 injector, rewire the y8 injector with the 95 ex hardness injector and just wire the vtec wire to ur ecu, and dont worry about the sensor, for my it run pretty good in the 1/4 miles, did a 14.7, if i have some pics ill post them up too.</TD></TR></TABLE>
hmm so u used the y8manifold? what did u do about the FITV hook up? there isnt one on a d16y8 but there is on all the obd 1 cars.. what did u do with the coolant lines?
Old Apr 29, 2005 | 05:41 PM
Otherguy's Avatar
NASIOC.com
Default Re: (POE)
you would eat the extra coolant lines, because they arent needed
Old Apr 29, 2005 | 05:54 PM
civicboisi's Avatar
you're doing exactly what i'll be doing...i don't think this topic has been covered much the Poe cuz searching isn't doing me any justice either on this topic
but insted of a y8, i'm swappin in the y7
Old Apr 29, 2005 | 07:13 PM
POE's Avatar
POE
cool, so i just bypass the lines....?
Pablo1997
Jun 18, 2016 06:55 AM
Wrench6
18
Jul 4, 2015 10:50 AM
95vr6man
Feb 5, 2006 10:03 AM
