integra brakes...need knucles for del sol?
I want to upgrade my calipers to something a litte bigger since i just put in the wrong sized brake master cylinder. can an integra caliper bolt up?
You need different knuckles if your going from 9.4" rotors to 10.2". You can use:
92-00 Civic & Del Sol with ABS
93-00 Civic EX 2dr
99-00 Civic Si 2dr
94 Del Sol Vtec
90+ Integra
What size master cylinder did you install?
If it's a 7/8" you will need civic calipers (from any of the civic/sol listed above). If it's a 15/16" or larger, you will need integra calipers...
93-00 Civic EX 2dr
99-00 Civic Si 2dr
94 Del Sol Vtec
90+ Integra
haha, thats like any knuckle except mine LOL. yeah i got the 15/16 MC installed. where can i get knuckles, and how much should i be spending for them?
also, do i need to get different brake lines if i use integra calipers?
It sounds to me like you need the whole front brake assembly. I believe that Hmotorsonline sells them for $75 a pair (calipers/rotors/knuckles). I would probably opt to buy from ImportAutoSalvage though (contact Larry Jr.). They guarantee ALL their parts, and have super cheap shipping. If you have a problem with any of their normal used parts, they'll replace it (I know from experience). Make sure your getting the brake lines too, otherwise your going to have to hunt some down...
Your going to need to buy pads/rotors/shims/retainers no matter who you source the parts from, so be prepared. These items deteriorate very quickly in a salvage yard...
Hmotorsonline looks like it is much cheaper compared to ImportAutoSalvage. ImportAutoSalvage is selling the front spindle for 70 bucks with shippping for each side, not including the calipers. is there a different between integras with abs or non-abs? is there anything else i need to know regarding the brake swap?
i need: calipers, rotors, pads, spindles/knuckles (same right?), retainers and lines. swap is direct bolt on without any modifications?
sweetness, you guys are really helpful. i just gave them a call, ill have to pick them up on the weekend. last question: can i still use stock delsol wheels? 14's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duh blacksheep »</TD></TR><TR><TD CLASS="quote">sweetness, you guys are really helpful. i just gave them a call, ill have to pick them up on the weekend. last question: can i still use stock delsol wheels? 14's</TD></TR></TABLE>
Civic EX 2dr comes with 14" wheels and 10.2" brakes, so you should be good to go...
the guy i talked to said the knuckles/spindles do not include wheel bearings...which one am i supposed to buy so that it fits a delsol axle and an integra hub?
I think you can use your old bearings & hubs (not 100% though). You may also want to transfer your lower balljoints IF the ones on the new knuckles don't feel tight & smooth.
Make sure you take the time to dissassemble, clean & lube all the new parts you get. The caliper guide pins are super important. If they freeze up, your whole caliper is junk since you won't be able to disassemble it. If the new lower balljoint feels good, make sure to jently remove the boot & re lube it also. You will also wan't to pack the bearings before you install them into the new knuckles. It seems like a lot of work, but it's deffinently worth it in the long run...
Does anybody else know if you can use the smaller knuckle's "hub/bearings" on the EX/Teg knuckle?
SiRay6
Jul 24, 2020 02:03 PM
jachrist
Sep 29, 2009 05:48 AM
delsolnewkid
Mar 13, 2006 07:20 AM
phantom_sol
Oct 7, 2003 01:56 PM
