help with GSR brake conversion for del sol
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
Hey guys,
I am searching for a thread with the info I need, but not having much luck.
I want to change the front calipers on my 1995 del sol si and put GSR calipers on it because they are "supposedly" a lot better. I need to buy new rotors and pads for the stock brakes, so I'm thinking about just swapping them out now.
BUT... what do I need besides new calipers and rotors? do I need mounting brackets, a new brake booster, etc.???
Any help is GREATLY appreciated.
Seagull Management
In addition to what you mentioned, you will need the following:
-'94 - 01 Integra front knuckles
-'91 Civic EX Master cylinder or '94 - '97 Integra RS (non ABS) master cylinder & brake booster
-'94 - '97 Integra RS (non ABS) proporting valve, or '90 - '93 non ABS Integra proportioning valve, resusing the civic bracket from the original proportioning valve.
what ^^^ said. if your interested i have new never installed cross drilled rotors and the used porporting valve you need. pm me if your interested
zombieD
11-17-2010 09:51 AM
duh blacksheep
12
04-26-2005 07:53 AM
jspresso
07-19-2004 12:39 PM
