obd2 B18b1 swap into a 1998 Ek
Old Apr 24, 2005 | 07:02 PM
Touge Tuning's Avatar
Default obd2 B18b1 swap into a 1998 Ek
Hey guys, im preparing to do my B18b1 swap into my EK coupe and i just wanna get a few little things figured out. I have searched and searched and havent found definitive answers to my questions so thats why im making a thread.
1. For the IACV fix can i re-use my D series connector and just re-pin at the ECU or do I NEED to get the teg one?
2. How much short or long will the exhaust be putting the B series engine with LS manifold and i believe teg cat onto a 98 DX (cat at the manifold)?
3. Would i be better running an OBD1 ECU with a conversion harness so i dont needa mess with the CFK and O2 secondary sensor or will the car run better with an OBD2a LS ecu?
4. What belts do i or can i use from the D series on the B series? I have a custom alt and im pretty sure it will bolt into the B series brackets but i just wanna make sure. For the AC im getting the del slo ac bracket and using hte D series pump but what belt do i use? can i use the D series one or will it be too short/long? For the PS i need the B series bracket and pump and im guessing i cant use the D series belt on that?
Thanks in advance for any help u guys can give me
Old Apr 25, 2005 | 05:35 AM
Someone has to have answers on here guys?
Old Apr 25, 2005 | 01:32 PM
Old Apr 25, 2005 | 01:46 PM
after digging a little it seems i NEED the 2-wire IACV sensor and that i need to switch 1 pin on the ECU side. Now if im gonna be using an OBD1 LS ecu with a conversion harness how do i go about doing the pin swapping?
Old Apr 26, 2005 | 10:55 AM
TTT
JPerkMr954
Aug 11, 2011 01:05 PM
FearDisH22a4
43
Feb 18, 2010 09:07 AM
mmafighter130
Nov 27, 2007 04:08 AM
vvvvvvv
Jul 20, 2007 11:32 AM
vtecftw
Jul 9, 2007 06:32 PM
