H22 O2 sensor CEL??
alright i have a h22 in an accord with Hondata P28 ecu. I only have the one check engine light which is a code 41 (o2 sensor heater) i believe. Now i when i first finished the swap i hadnt switched the 02 sensor and egr wires for a couple of days, could this of messed up the heater circuit???
also with this particular code could this be causing any performance problems or any problems at all???
[QUOTE=95accordh22a]alright i have a h22 in an accord with Hondata P28 ecu. I only have the one check engine light which is a code 41 (o2 sensor heater) i believe. Now i when i first finished the swap i hadnt switched the 02 sensor and egr wires for a couple of days, could this of messed up the heater circuit???
QUOTE]
Are you saying you did mix up egr and o2 or not? I really don't understand what you are looking for here. Just get an ecu pinout diagram and make sure the wires are running to the correct pinouts.
QUOTE]
he said ....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95accordh22a »</TD></TR><TR><TD CLASS="quote">Now when i first finished the swap i hadnt switched the 02 sensor and egr wires for a couple of days,</TD></TR></TABLE>
so he has already switched them. he is asking if it could have messed anything up, and if it could give him any problems
scrubachu
Jul 31, 2001 10:36 AM
