Just finished b16 swap, getting a code, need help
Old Apr 24, 2005 | 04:09 PM
white91rex's Avatar
Default Just finished b16 swap, getting a code, need help
I just finished a b16a swap in my 1990 crx si. I am using the hasport v-tec harness. I took it out for a spin. The check engine light came on and the car started to stall when I would stop the car. I checked the code at the ecu. I do not know what number code this is ( if someone knows please let me know) I get 2 slow flashes inthen 2 fast flashes. Any idead?
-chris
Old Apr 24, 2005 | 04:13 PM
lodo1's Avatar
Default Re: Just finished b16 swap, getting a code, need help (white91rex)
that would be code 22, and the code is i believe vtec oil pressure - check your oil
Old Apr 24, 2005 | 04:23 PM
white91rex's Avatar
Default Re: Just finished b16 swap, getting a code, need help (tdocrx)
The engine oil is full, the V-tec oil pressure switch is hooked up as well. I can;t tell if v-tec is kickin in. I did not pull when I hit 5500 like it does in my friend;s crx. It felts like a regular motor. Also my exhaust is not hooked up so it is really loud ( could not hear the v-tec scream) Is their a way to test the switch with a meter?
-chris
wrx'n you
Feb 3, 2007 01:07 AM
McNizzle
Apr 28, 2004 05:44 AM
endlesswinterco
Jan 10, 2004 01:26 PM
f1nal zeros
Aug 22, 2002 11:36 AM
typer_801
Mar 19, 2002 07:08 AM
