Help Shiffting Problem!!!!!
Old Apr 24, 2005 | 03:33 PM
THugluv423's Avatar
Default Help Shiffting Problem!!!!!
I swapped a Jdm B18c into my 99 si about 1500 miles ago. I replaced the Manual tranny fluid when I did the swap. The problem is that It shifted perfectly until yesterday. When I shift around 2 grand it shifts ok but If I shift any higher It feels like I gotta put my arm into it to get it out of gear. Cant figure out the prob please guys help me??????? What should I do.
Old Apr 24, 2005 | 03:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Help Shiffting Problem!!!!! (THugluv423)
rest your foot on your clutch pedal, if it sinks slowly, replace the clutch master. it may not be fully disengaging. also what fluid did you use? i know everyone uses their preference, i use honda mtf. just want to make sure you didnt use gear oil.
Old Apr 24, 2005 | 04:08 PM
THugluv423's Avatar
Default Re: Help Shiffting Problem!!!!! (boostedcivicsir)
I used the honda fluid. I also replaced the clutch slave and master when I first did the swap. I hope that helps
Old Apr 24, 2005 | 05:18 PM
Above6K's Avatar
Did you try checking the linkage? My friend ran over a curb and bent his, same symptoms.
Old Apr 24, 2005 | 05:25 PM
Mr. Badwrench
Default Re: Help Shiffting Problem!!!!! (Above6K)
if you replaced the clutch slave and master, it is possible that you have the incorrect adjustment on the master cylinder. make sure you have 3/4" of free play before the clutch starts to disengage.
Old Apr 24, 2005 | 07:08 PM
THugluv423's Avatar
i need more help
Old Apr 25, 2005 | 07:26 AM
THugluv423's Avatar
anyone
Old Apr 25, 2005 | 07:36 AM
IHateJDM's Avatar
how well did you bleed your clutch lines?
Old Apr 25, 2005 | 07:38 AM
THugluv423's Avatar
Default Re: Help Shiffting Problem!!!!! (IHateJDM)
Im sure I did it well. The point is that It work perfectly till yesterday. thats been 1500 miles since I bled it.
Old Apr 25, 2005 | 06:45 PM
THugluv423's Avatar
need more help
BeRightBack
Mar 8, 2009 12:29 PM
islandhonda
Jun 1, 2007 09:02 AM
civicandr6
Mar 16, 2007 07:18 PM
Akalima
Sep 17, 2005 10:11 PM
Peasonrice
May 5, 2005 04:17 PM
