Help Shiffting Problem!!!!!
I swapped a Jdm B18c into my 99 si about 1500 miles ago. I replaced the Manual tranny fluid when I did the swap. The problem is that It shifted perfectly until yesterday. When I shift around 2 grand it shifts ok but If I shift any higher It feels like I gotta put my arm into it to get it out of gear. Cant figure out the prob please guys help me??????? What should I do.
Mr. Badwrench
Re: Help Shiffting Problem!!!!! (THugluv423)
rest your foot on your clutch pedal, if it sinks slowly, replace the clutch master. it may not be fully disengaging. also what fluid did you use? i know everyone uses their preference, i use honda mtf. just want to make sure you didnt use gear oil.
Re: Help Shiffting Problem!!!!! (boostedcivicsir)
I used the honda fluid. I also replaced the clutch slave and master when I first did the swap. I hope that helps
Mr. Badwrench
Re: Help Shiffting Problem!!!!! (Above6K)
if you replaced the clutch slave and master, it is possible that you have the incorrect adjustment on the master cylinder. make sure you have 3/4" of free play before the clutch starts to disengage.
Re: Help Shiffting Problem!!!!! (IHateJDM)
Im sure I did it well. The point is that It work perfectly till yesterday. thats been 1500 miles since I bled it.
