What does it take to install a spoon cluster?
Old Jan 31, 2002 | 03:09 PM
AllMotorITR's Avatar
New User
Default What does it take to install a spoon cluster?
I have possibly found a cluster that I am going to buy, and I was just curious if it was hard to install and what it takes to install a Spoon cluster.. Need info asap. Thanks guys!
Old Jan 31, 2002 | 03:10 PM
jonas's Avatar
Default Re: What does it take to install a spoon cluster? (1 FAST R)
if its as easy as installing a cluster in a civic,
then its easier than pumping gas
Chris93Si's Avatar
If your buying one for an Integra it should just be plug n' play. Easy.
Old Jan 31, 2002 | 03:15 PM
uber_nihilist's Avatar
a lotta luck
Old Jan 31, 2002 | 03:58 PM
Cosworth's Avatar
If I remember correctly... ~6 screws, 3 or 4 wire plugs. That's it.
Total installation time = ~5 minutes.
[edit] there are two screws by the plastic trim, and I think 4 screws hold the cluster to the dash [/edit]
[Modified by Cosworth, 10:30 PM 1/31/2002]
Old Jan 31, 2002 | 03:59 PM
B2FiNiTY's Avatar
Default Re: What does it take to install a spoon cluster? (Cosworth)
How do you pop the plastic piece off?
Old Jan 31, 2002 | 04:00 PM
Mario's Avatar
Default Re: What does it take to install a spoon cluster? (B2FiNiTY)
Pull that sucker and hope the clips dont break.
Helms.
Old Jan 31, 2002 | 04:19 PM
koy's Avatar
koy
New User
Default Re: What does it take to install a spoon cluster? (Supersonic DC2)
bummer... i had to swap the plastic circuit sheet over...but it works fine
Old Jan 31, 2002 | 04:59 PM
Cosworth's Avatar
Default Re: What does it take to install a spoon cluster? (koy)
koy - OT, but weren't you gonna setup some group buy on MOMO horn button adaptor thingie?
Celvinchin
Dec 4, 2018 02:39 AM
enda
Jul 5, 2008 07:35 PM
slpr_civic93
May 15, 2006 04:45 PM
Civmochris
Mar 8, 2004 06:43 PM
AllMotorITR
May 25, 2002 11:50 AM
