ft lbs to in lbs conversion
Old Apr 24, 2005 | 03:01 PM
sickity's Avatar
Default ft lbs to in lbs conversion
what is the conversion factor? like 1ft lb = X in lbs........
would you just multiply it by 12in/1ft?
Old Apr 24, 2005 | 03:10 PM
The Phil's Avatar
Default Re: ft lbs to in lbs conversion (sickity)
to convert ft lbs to in lbs, multiply by 12. Not 12in/1ft because that's 1/1. Coefficients don't have units on them.
Old Apr 24, 2005 | 03:20 PM
Frozen E's Avatar
H-T White Ops
12 lb/ft = 144 in/ft
Old Apr 24, 2005 | 03:23 PM
Frozen E's Avatar
H-T White Ops
Found this
http://www.convert-me.com/en/convert/torque
Old Apr 24, 2005 | 04:09 PM
sickity's Avatar
Default Re: ft lbs to in lbs conversion (xthephilx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">to convert ft lbs to in lbs, multiply by 12. Not 12in/1ft because that's 1/1. Coefficients don't have units on them.</TD></TR></TABLE>
multiplying 12/1 is same as multiplying by 12... as it is 12in per 1ft, and the ft cancels out and leaves you with inch lbs...just wanted to make sure no other conversions in the measurements were needed...thanks
Old Apr 24, 2005 | 07:47 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickity &raquo;</TD></TR><TR><TD CLASS="quote">multiplying 12/1 is same as multiplying by 12... as it is 12in per 1ft, and the ft cancels out and leaves you with inch lbs...just wanted to make sure no other conversions in the measurements were needed...thanks</TD></TR></TABLE>
My head hurts.
Old Apr 24, 2005 | 07:50 PM
skip.two's Avatar
wow basic algebra...
Old Apr 24, 2005 | 10:29 PM
Stoich EG2's Avatar
Default Re: ft lbs to in lbs conversion (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">wow basic algebra... </TD></TR></TABLE>
not even. 2nd grade math y0
jthm
Jan 16, 2007 06:40 AM
N20civicB18
Suspension & Brakes
Feb 22, 2006 04:44 PM
invidiaeg6
Nov 22, 2004 08:39 PM
Short Round
Mar 9, 2004 01:19 PM
delslow94
Dec 25, 2002 06:53 PM
