A little oil on the spark plugs.....
Old Apr 23, 2005 | 02:40 PM
Flux's Avatar
Default A little oil on the spark plugs.....
Just changed my spark plugs with some new stockers. The old plugs look great but I noticed just a tiny bit of oil on them - really not much at all. Is this normal or is it an indication of something else that I can catch now?
Old Apr 23, 2005 | 02:43 PM
Bbasso's Avatar
Default Re: A little oil on the spark plugs..... (Flux)
how hard were you driving before you took them out?
Old Apr 23, 2005 | 03:01 PM
RTW DC2R's Avatar
on the electrode? or the threads? does the car smoke at all? I wouldnt be too worried about it unless you are smoking a lot or using up a lot of oil.
Old Apr 23, 2005 | 05:15 PM
Flux's Avatar
Default Re: A little oil on the spark plugs..... (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">how hard were you driving before you took them out?</TD></TR></TABLE>
Car hadn't been driven in a week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW &raquo;</TD></TR><TR><TD CLASS="quote">on the electrode? or the threads? does the car smoke at all? I wouldnt be too worried about it unless you are smoking a lot or using up a lot of oil. </TD></TR></TABLE>
On the threads. I'm not too worried about it since it was small amount and I am not smoking at all...
Old Apr 23, 2005 | 05:25 PM
Bbasso's Avatar
I would not worry, drive it hard for a while then pull the plugs out asap after. then look, I'll bet they look nice.
Old Apr 23, 2005 | 05:50 PM
r573's Avatar
Even if it was it would most likley be the spark plug o rings and that is super easy to change.
Old Apr 23, 2005 | 07:43 PM
vtec.dc2's Avatar
do a compression test
Old Apr 23, 2005 | 07:56 PM
Chubz's Avatar
Default Re: A little oil on the spark plugs..... (vtec.dc2)
its the spark plug gromets on the valve cover. I just had the same problem...all gone after i changed it
Old Apr 23, 2005 | 08:25 PM
TypeR15's Avatar
Default Re: A little oil on the spark plugs..... (Chubzilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chubzilla &raquo;</TD></TR><TR><TD CLASS="quote">its the spark plug gromets on the valve cover. I just had the same problem...all gone after i changed it</TD></TR></TABLE>
yes i had the same problem....just got new gromets for the valve cover and i was good to roll
sedlmeier101
Sep 4, 2007 09:15 AM
ReggieGrip
Feb 26, 2006 08:13 PM
BlazeTeck2000
Feb 11, 2005 01:05 PM
S2k ALeN
Aug 7, 2003 02:44 PM
Digital-R
Aug 3, 2001 11:07 AM
