Oil pressure shot up after JDM D15B swap
Old Apr 23, 2005 | 08:03 AM
T-RO's Avatar
Default Oil pressure shot up after JDM D15B swap
I previously had a boosted D16z6 in my Civic. I just swapped in a JDM D15B w/ the same turbo setup.
Old oil pressure was like 20 at idle 30-40 at cruise and a bit more on highway.
New oil pressure is like 50-60 at cruising
Any idea why?
Old Apr 23, 2005 | 02:45 PM
ironlung78's Avatar
Default Re: Oil pressure shot up after JDM D15B swap (T-RO)
my b16 is right around what your new engine is.
usually as high as 75 at a cold start.
Old Apr 27, 2005 | 05:41 AM
T-RO's Avatar
would running synthetic oil have anything to do with it?
Last time i used regular oil and this time im running full synthetic
Old Apr 27, 2005 | 10:34 AM
D15B_Ej6's Avatar
The oil viscosity could have something to do with it and the basic fact that its a different engine. Even though the z6 and d15b share the same head, the block is still a little different.
Old May 1, 2005 | 09:58 AM
Thrillhouse's Avatar
Default Re: (D15B_Ej6)
Force = Pressure x Area .............. so basically pressure = area / force
Force = oil pump
Area = bearing clearances, oil galley sizes and so forth
So basically for your oil pressure to go up those things must have changed
Its a different engine Im assuming built differently
joshledbetter12
Jan 28, 2014 12:15 PM
an2ny888
May 6, 2013 10:31 AM
on2wheels
Jan 25, 2008 06:39 PM
bonylad
Sep 13, 2006 09:50 AM
DLB1994
Nov 8, 2003 10:11 PM
