turbo d16y7...what fuel pressure.
I just put a turbo kit on my d16y7....and i think it is running way too rich. I put everything on and did not adjust anything, such as fuel pressure or timing. What is the stock fuel pressure supposed to be for the d16y7 and What should my fuel pressure be set at with the turbo setup on. I am running 5 psi. I am still running the stock fpr...but i am gonna get an adjustable one tomorrow.
Here is my setup.
greddy turbo and manifold
spoolin performance dp
spoolin performance intercooler piping
jrc intercooler
vortech 12:1 fmu
synapse missing link
walbro 255 high pressure in-tank pump
ngk bkr7e plugs
Here is my setup.
jrc intercooler
vortech 12:1 fmu
ngk bkr7e plugs
if you're using the fmu, when you try to turn the fuel psi down, the psi wont go down, you have to eliminate the fmu then adjust the psi and then hook the fmu back up. stock psi is 40-45, turn it down to 30psi.
