Car sputters and bogs in gear, but not in idle...WtF!!??!! Help please
Old Apr 22, 2005 | 05:46 PM
vg7z's Avatar
Default Car sputters and bogs in gear, but not in idle...WtF!!??!! Help please
ok
car is 94 civic ex
i was drivin around today, goin at atbout 5mph i punched it in 1st and it statr sputtering the rpms would just jump up and down...then i kept driving, itd sometimes sputter on light throttle
i reved it up in neutrel and everythins OK
anyone have any idea what could be wrong?
Old Apr 22, 2005 | 05:56 PM
Cypher0117's Avatar
Default Re: Car sputters and bogs in gear, but not in idle...WtF!!??!! Help please (vg7z)
do u have a manual or automatic trans.. and does it bog down at all rpms or just when you are starting?
Old Apr 22, 2005 | 06:04 PM
vg7z's Avatar
its a manuyal
it doesnt bog in neutral but in gear
it bogs mostly in 1st gear, at first ONLY WOT, but now it bogs at light throttle
Old Apr 22, 2005 | 06:25 PM
Cypher0117's Avatar
Default Re: (vg7z)
does it make any noise? or does it just bog down.
Old Apr 22, 2005 | 06:26 PM
vg7z's Avatar
no noise
just bogs and stutters has a hard time acceleratiing
Old Apr 22, 2005 | 06:30 PM
e jay one's Avatar
Default Re: (vg7z)
when you slam the pedal does it bog then go? check the timing.
Old Apr 22, 2005 | 06:36 PM
vg7z's Avatar
its not really a bog, its more of a stutter and the engine like misses or somethin...itll shake back and forth it acts like if i was steppin on the gas and letting off as fast as i could
Old Apr 22, 2005 | 06:42 PM
civiccpedx's Avatar
Default Re: (vg7z)
i would check the ignition system, ie spark plugs, spark plug wires, dizzy cap and rotor. that was the problem on mine and it bogged like yours
Old Apr 22, 2005 | 08:08 PM
vg7z's Avatar
bump 4 mpotr help
Old Apr 22, 2005 | 08:37 PM
ek hatchhh's Avatar
first stop - plugs/wires
Old Apr 23, 2005 | 03:45 PM
Jmunk's Avatar
I had that problem once, it was a bad oxygen sensor. If you unplug the oxygen sensor and it stops doing it than you've found your problem.
Old Apr 23, 2005 | 03:47 PM
Weapon_R's Avatar
Used to have the exact same problem and it was the o2 sensor!
Easiest way to check is to unplug the o2. You may throw a code, but you'll know if thats the problem and it doesn't cost a penny. Make sure you tie the harness away from the hot pipes or you'll be looking for a new harness after it melts :D
Old Apr 23, 2005 | 06:32 PM
vg7z's Avatar
its probably the o2 sensor, cuz im runnin a dc 4-1 header and the o2 sensor is hooked up hella ghetto
Old Apr 23, 2005 | 07:21 PM
Weapon_R's Avatar
It only takes 10 seconds to find out. Jack up, unplug, and tape your harness safely away from the exhaust pipes ...
Even the dealer couldn't figure out why my car was bogging since it wasnt throwing any codes, but it was the o2!
gsaldana10
Honda Civic (2001 - 2005)
Jan 17, 2017 07:20 AM
BombayBeats
15
Sep 18, 2015 01:22 PM
subworm07
Jan 26, 2011 02:49 PM
turbotime
Jul 11, 2006 08:20 AM
Drew96EJ
Aug 21, 2004 06:22 PM
