Aftermarket rotors and engine dampers ?'s
Is there any gain in changing my OEM rotors with Brembo blanks or slotted?
Also, If one of my engine mounts is busted causing me to misshift or grind a gear would an engine damper temporarily fix this problem?
Re: Aftermarket rotors and engine dampers ?'s (chowmien)
i personaly see no difference between oem and blembo or any blank rotor for that matter. deffinatly fix the broken mount too. you dont need slotted or cross drilled rotors for a daily driven car it will wear your pads down faster.
Texas_EG
25
09-29-2006 09:39 AM
