HELP electrical problem on del sol
Old Apr 22, 2005 | 04:50 PM
boosted_soul_94's Avatar
Default HELP electrical problem on del sol
hey i just recently got my car back from a stero shop down south. and when i dropped it off everything was in working condition. NEXT thing i know i picked it up and and there is a bunch of electrical stuff wrong with it. MY gauge cluster doesn't work. my brake light/park light doesn't work. my fuses keep on blowing everytime i put a new one in. Then i just got tired of this and riped out my whole system, took out my deck. THEN i put a brand new fuse in there and certainly the fuse blew again for my park lights. I know there is a short somewhere but im not sure where? can you guys possibly tell me where to look or anything? thanks
Old Apr 22, 2005 | 04:53 PM
cdizzle's Avatar
check ur grounds get them to look at it again?????? if they did a bad job they should fix it
Old Apr 22, 2005 | 04:59 PM
99blackcivicSi's Avatar
Default Re: (cdizzle)
take it back to them, thats all ic an say, or you have to get the wireing diagram for the car, and check it out, cuz theres no way i can tell you what those wires do without looking at seeing where they are getting power, and the power flow of them, 2 things you definatly need, 1 a wiring diagram, to check out the meter leights, and check the park lights, theres more on that fuse than the parking lights, and start playing around with the other stuff that is on the parking light fuse. and get that fixed and go from there, also check to make sure its not a melted bulb somewhere in the system, yes i have seen bulbs do some stuff like that if you got anything else u want to ask ask away i'm glad to help
so two things...
multimeter
wiring diagram
stay away form a test light for this one i don even use a test light unless its checking fuses for power thats it, everything else is done through my multimeter cuz it gives you accual readings, you have to have a good meter though, i recomned Fluke or Blue Point, i love my Blue Point meter, but in school i use a Fluke which is a good quality meter also
Old Apr 22, 2005 | 05:04 PM
Default Re: (99blackcivicSi)
yea i would bring it bak to them to fix it but the problem is that i live in sacramento and the shop is located in LA! and i am not driving there with no brake or park lights...=/ basically they screwed me over...but i am going to try to look for a diagram on my car. if anyone has one that would be GREAT!
Old Apr 23, 2005 | 04:19 PM
ryanbartholomew85's Avatar
Default Re: (techna_sol_94)
damn dude, the same thing happened to me, my guage cluster light, and brake and turnsignals didnt work, i had to get a whole new fuse block, and it fixed everything, but the guage cluster lights still dont work.... id like to know what you do to fix it , cause i want my fkn lights back on LOL... good luck!
Old Apr 25, 2005 | 04:18 PM
Default Re: (ryanbartholomew85)
hey wasup bro...yea maybe its the whole fuse box cover but then only ONE fuse keeps on blowing out and thats my park light. im not to sure whats going on with my brake lights.i wonder if there is a fuse for that one.but im going to take it to my friends shop and he is going to check everything out. but my other friends says it a loose ground wire ( short ) somewhere. But what happen to my gauge cluster was that the fuse was blown and when i put a new one in there it worked. but good luck i hope you find out the problem
delsoldriver96
10
Jul 31, 2013 09:38 AM
TurboTim10
Apr 10, 2010 10:33 AM
tsispyder97
May 17, 2005 07:42 PM
underpressure02
Jan 15, 2005 10:37 PM
1C9R9X3
Jan 30, 2004 02:15 PM
