How do you get the Horn working with a boss hub kit???
Old Apr 22, 2005 | 10:05 AM
turbotime's Avatar
Default How do you get the Horn working with a boss hub kit???
I want a horn for my quick release but for the boss hub kit i had to remove the srs thingy... so how do i hook the horn up?
Any help is mucho gracias, i live in NY where a horn IS NEEDED.
Thanks
Old Apr 22, 2005 | 10:12 AM
turbotime's Avatar
honk
Old Apr 22, 2005 | 10:59 AM
monicle's Avatar
Default Re: How do you get the Horn working with a boss hub kit??? (turbotime)
ground one of the wires to the side of the boss. thats it.
Old Apr 22, 2005 | 11:04 AM
turbotime's Avatar
well i mean the SRS unit had to be removed, and the horn wire was in it...
So how do i get the + wire for the horn now? Since the SRS round thing with cruis/horn wires is gone?
Old Apr 22, 2005 | 11:11 AM
monicle's Avatar
Default Re: (turbotime)
you shouldnt have removed it. you should have just shorted the srs system. put it back on and give me a picture of the srs cable and Ill tell you how to short it.
this is an example of how you do it on a 99-00 civic.
Old Apr 22, 2005 | 11:52 AM
turbotime's Avatar
well i couldnt get the boss hub on without removing the SRS unit..
Old Apr 22, 2005 | 03:18 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (monicle)
hey monicle glad to see that quick release is working for u. Quick question, what kind of hub adapter is that? I like that it has that slot where the wires for the SRS come out. I had to remove mine to get the momo hub to fit.
Old Apr 23, 2005 | 06:39 AM
monicle's Avatar
Default Re: (rukawa1one)
its the Works Bell/Splash short boss. I picked mine up in japan but I think you can get them here for a bit more $$$. I had to pay $136 for mine over there.
Old Apr 23, 2005 | 10:27 AM
rukawa1one's Avatar
Oh yes I've heard of those before. Ya pretty pricey, but they are really high quality and nice to look at unlike momo, hkb and other hubs
Old Apr 23, 2005 | 11:10 AM
saxqtzk's Avatar
Default Re:
I just installed a new steering wheel myself in a 98 and it's actually pretty simple. You have to get a shoehorn from honda and trim it a little to screw on. The shoehorn has a male or female connector on it that plugs in underneath the steering column near the headlight switch meanwhile the other end will make contact with the copper backing on the hub...
If you're unsure what the shoehorn is there is a thread regarding it somewhere on the forum.
Once you get the shoehorn installed you have to connect the wire from the hub to the horn button and the other wire from the horn ring.
Mine works perfectly except yesterday when one of the little connectors behind the horn shifted and touched the other wire engaging my airhorns at 1am... It's safe to assume my neighbors weren't happy.
btw, i'm using a momo hub with a sparco lap5 steering wheel.
Old Apr 23, 2005 | 11:50 AM
turbotime's Avatar
so i need a shoehorn..?
I searched the eg forum and couldnt find anything about shoehorns, do you know where i could get one? There are no junkyards round here...
Old Apr 23, 2005 | 12:58 PM
saxqtzk's Avatar
the shoehorn?
get it at honda for under $6
Part Number: 35259-SH3-A02
here's an idea of how to install it. IM me if you have more questions, I'm more than happy to help.
Just a recap to make it easier:
The shoe horn
One end touches the backside of the hub. The other end connects to a male connector that is already located on the underside of the steering column.
There is a wire out of the hub that connects to one of two connectors on the horn button. There is another wire that hooks up to the horn ring that also connects to the horn.
So two wires all together.
Viola you are done.
PROPS TO dnt94civic
Old Apr 23, 2005 | 12:59 PM
saxqtzk's Avatar
Default Re: (saxqtzk)
also you can see in the picture the little red circles. Those are pieces you need to snip to make it fit. I believe the shoe horn is originally from a 88-91 civic.
johnmota
Jul 13, 2015 06:37 AM
jardine90si
Aug 9, 2011 06:53 AM
scottso990
Apr 22, 2011 01:14 AM
es_squared
Sep 21, 2006 09:11 PM
