how much should oil feed line flow?
Old Apr 22, 2005 | 10:04 AM
screen_name's Avatar
Default how much should oil feed line flow?
i hooked up my oil feed and tried running it while it was off the turbo to see how much it flowed and it flowed a shitload just didnt look right for somereason... how much is too much flow?
Old Apr 22, 2005 | 10:26 AM
Default Re: how much should oil feed line flow? (LB562)
Old Apr 22, 2005 | 10:28 AM
BlueShadow's Avatar
It's the pressure you should be worried about. IIRC turbos only need about 30-40 PSI of oil pressure. I believe the sources that we tap for our feed lines go as high as 60-80 at close to redline.
Old Apr 22, 2005 | 07:00 PM
Default Re: how much should oil feed line flow? (BlueShadow)
so i need an oil pressure between the feed line and the T?
Old Apr 23, 2005 | 06:12 AM
up
Old Apr 23, 2005 | 06:19 AM
BlueShadow's Avatar
A lot of people will say if you run a 3 AN size feed line you will be fine. But I think it's a good idea to run an oil restrictor which will limit the amount of oil pressure that goes to the turbo. Like I said, the oiling sytem in your average VTEC car gets about as high as 6-80 PSI, or somewhere around there. A turbo only needs 30-40 PSI of oil pressure, any more pressure and the oil seals in the turbo will fail (oil in the intake/downpipe).
Old Apr 23, 2005 | 07:00 AM
TOP_END_Turbo_GSR's Avatar
wat does an oil restrictor look like and who makes one?
Old Apr 23, 2005 | 07:22 AM
BlueShadow's Avatar
Default Re: how much should oil feed line flow? (TOP_END_Turbo_GSR)
atpturbo.com sells them, you just screw it into the turbo oil inlet, and the feed line attaches to it.
http://www.atpturbo.com/Mercha...e=OIL
stealthmodeperformance.com sells adjustable ones, but if you dont know how to adjust it, then it is possible to have the oil pressure too high or too low.
http://www.stealthmodeperforma...shtml
Turboredteg
Feb 7, 2005 06:38 PM
wade
Oct 10, 2004 07:38 PM
killa_lude
Aug 21, 2004 11:44 AM
gigantor
Feb 11, 2003 08:06 AM
GruvyTune
Feb 5, 2002 03:27 PM
