HELP! Head swap problems
Old Apr 22, 2005 | 09:50 AM
ebp_dc2's Avatar
Default HELP! Head swap problems
Ok my car is a 98 integra with an 95 jdm h22a. I recently swapped a type s head onto the car, but im throwing a code 3. I can't seem to find a vaccuum schematic for the car to tell if i hooked up the vaccuum lines wrong...would this cause me to throw a code 3? Any help/schematics would be greatly apreciated! Thanks guys
Old Apr 22, 2005 | 11:05 AM
ebp_dc2's Avatar
Default Re: HELP! Head swap problems (h22d dc2)
come on guys help me out!
Old Apr 22, 2005 | 11:29 AM
Dragline's Avatar
Isn't the map sensor screwed to the throttle body with no vacum line?
Old Apr 22, 2005 | 02:22 PM
ebp_dc2's Avatar
Default Re: HELP! Head swap problems (dragline)
i think it does have a vaccuum line but im not positive...a schematic woudl be nice!
Old Apr 23, 2005 | 12:47 PM
SixguN's Avatar
Are you getting any other codes? Reason I ask is because when I started my h22 up, I ran a code 3,12,36,41. After I hooked the vac lines up correctly, and reset the ecu, I only had the code 12(egr) which is no biggie. Try and reset the ecu and make sure all vac lines are hooked up correctly. Your map sensor still might be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">Isn't the map sensor screwed to the throttle body with no vacum line?</TD></TR></TABLE>
Thats correct.
Old Apr 23, 2005 | 01:48 PM
ebp_dc2's Avatar
Default Re: HELP! Head swap problems (Sixgundone)
hmmmm anyhone got a vaccuum schematic..i relaly need one cuz i dont know where to hook up the vaccuum lines!
Old Apr 23, 2005 | 04:44 PM
SixguN's Avatar
I think this is what your looking for. Its on the first page.
https://honda-tech.com/zerothread?id=650329
Old Apr 23, 2005 | 04:51 PM
ebp_dc2's Avatar
hmm not seeing maybe im a huge idiot?
Old Apr 24, 2005 | 12:03 AM
SixguN's Avatar
Your lookin for a vac diagram, right? If so, it is on the first page. It is the second post.
d_boi_swag
Jul 5, 2009 12:14 PM
atmdc
11
Nov 15, 2007 09:28 PM
iandian
Oct 10, 2007 01:06 PM
barry11j
Aug 4, 2004 09:45 AM
kaj
Sep 27, 2003 09:36 AM
