Log manifold, cutting the fittings
I've just received my steel l's and t's to make my log manifold. What I'd like to know is do I cut the fittings (as indicated on the dotted lines) because they do not line up to the ports on the head. Or do I maybe have the wrong size fittings? They are 1.92inch OD (sorry dont know what that is in fraction form, from South Africa).
I just remember reading a thread here on how the fittings were cool because of the butt-weld design, so you can fill it with lots of weld, but if I slice them, I'll have to re-grind that edge? Also, quite a bit needs to be taken off each fitting, this makes the angles a lot sharper (SEE RED ARROW)....
Please help! Thanks!
Take as much as you can off the T's, and a little bit off of the 90's instead of taking the same off of each. You will have to re-bevel them and yes that angle will be sharper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic »</TD></TR><TR><TD CLASS="quote">Take as much as you can off the T's, and a little bit off of the 90's instead of taking the same off of each. </TD></TR></TABLE>
yea.
yea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">i made that manifold pictured. i do not take any material off of the 90's....i take it all off of the T's...and re-bevel them</TD></TR></TABLE>
yea, i didnt make that. and i didnt intend to act like i did. it was just a good example, like he said he doesnt cut the 90's.
exactly, even though its a log there is no reason to cheat the 90s. You should probably grind better bevels than they come with anyway. They are pretty half assed from the manufacturer.
Topdawgg
May 25, 2007 08:20 AM
b_ron007
Welding / Fabrication
27
Mar 10, 2006 08:01 PM
crxnug
Aug 2, 2005 05:56 PM
Nextelbuddy
Aug 26, 2003 10:37 AM
