Type S oversized pistons- hone or bore???
Old Apr 21, 2005 | 08:54 PM
luap's Avatar
Default Type S oversized pistons- hone or bore???
im debating on getting os pistons or standards, but if i do get os pistons will the machine shop hone to .25 over or bore to .25 over??? i have read some threads on this but i couldnt find an exact answer weather or not they will just bore or hone. And i was told it would run me $2000 to bore just to .25 over.
Old Apr 21, 2005 | 09:00 PM
Innovation's Avatar
Default Re: Type S oversized pistons- hone or bore??? (luap)
$2000 to bore .010?
Damn, I cant imagine what they would charge to install sleeves
Modified by Innovation at 10:12 PM 4/21/2005
Old Apr 21, 2005 | 10:19 PM
eMpAtHy's Avatar
i got sleeves done for 1000..they are totally overcharging..
Old Apr 22, 2005 | 08:06 AM
jostins_gsr's Avatar
Default Re: Type S oversized pistons- hone or bore??? (eMpAtHy)
so what do u guys suggest?
Old Apr 22, 2005 | 08:34 AM
v4lu3s's Avatar
RTFM
well if the pistons are .25 over you have to bore unless your block was rebuilt before and has been bored oversize already....
Old Apr 22, 2005 | 08:42 AM
Keewun's Avatar
Default Re: (v4lu3s)
i have a question. so if you get the standards size type s piston it will juss fit on them 93-96 h22 jdm motor? do u need new rods too? what kind?
Old Apr 22, 2005 | 08:57 AM
Innovation's Avatar
Default Re: (EG2SnailLike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2SnailLike &raquo;</TD></TR><TR><TD CLASS="quote">i have a question. so if you get the standards size type s piston it will juss fit on them 93-96 h22 jdm motor? do u need new rods too? what kind?</TD></TR></TABLE>
H22A4 rods
Old Apr 22, 2005 | 10:27 AM
v4lu3s's Avatar
RTFM
or you can have the stock rods rebushed to accept the floating wrist pins.
Old Apr 22, 2005 | 10:45 AM
.H22 POWER.'s Avatar
contact user name earl here on honda-tech. He has a deal with benson. Its around 1000 to sleeve, but dan benson is the best in the honda business.
Old Apr 23, 2005 | 06:02 PM
accord387's Avatar
wtf... 2k to bore and hone? it should definately be under 100 bucks for a 4 banger.
Old Apr 24, 2005 | 08:37 AM
georgiajdm's Avatar
if you get os pistons you need to bore so they fit, and then hone (cross hatch on the walls) which help to seat and seal rings.
you should still hone even if you go standard.
Old Apr 24, 2005 | 09:28 AM
rjr162's Avatar
Default Re: (georgiajdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">if you get os pistons you need to bore so they fit, and then hone (cross hatch on the walls) which help to seat and seal rings.
you should still hone even if you go standard.</TD></TR></TABLE>
I did this exact setup. To bore 10 over is like too small, or atleast the guy who did my setup said it wouldn't be worth it to bore it. He honed it out instead.
I also checked with Tempest Racing and Dynamic Motorsports, both shops saying they wouldn't bore FRM because it screws it up. I didn't ask about the honing at that point, but from all I learned researching (plus the helms instructions) it would be honed out, not bored.
Old Apr 24, 2005 | 11:09 AM
Keewun's Avatar
Default Re: (rjr162)
sorry to ask a newb question. but can someone tell me whats the different between hone and bore?
Old Apr 24, 2005 | 11:13 AM
georgiajdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2SnailLike &raquo;</TD></TR><TR><TD CLASS="quote">sorry to ask a newb question. but can someone tell me whats the different between hone and bore?</TD></TR></TABLE>
are you ignorant or lazy? it's 2 posts above yours and then quoted again....
Old Apr 24, 2005 | 08:22 PM
SlOwDc2-R's Avatar
pm ludeboy555 he put in os .25 type s pistons in to his 97 lude i forgot how much it cost him but its around $300-$500 for bore and hone, micro polish crank and balance hit him up
Old Apr 27, 2005 | 08:11 AM
luap's Avatar
Default Re: (SiR-EK)
thanks for your input guys.
q8delsol
Nov 13, 2007 05:09 PM
.BigSexy
Feb 11, 2007 09:10 PM
99blackvti
Sep 7, 2005 01:46 PM
roydogg
Aug 6, 2003 06:49 AM
