does the jdm d15b vtec have this part?
Old Apr 21, 2005 | 04:33 PM
tsjeff's Avatar
Default does the jdm d15b vtec have this part?
I'm trying to see if the d15b vtec has this because on my block I don't know if it's a thing where I connect a tube to. In the pic, mine does not stick out far enough where I can connect a tube to it. Can it just be broken or is it not used?
Old Apr 21, 2005 | 04:40 PM
nabeleda's Avatar
Default Re: does the jdm d15b vtec have this part? (9 3 d e l s o l)
i have the same motor.
Old Apr 21, 2005 | 05:06 PM
dnoredsi's Avatar
i'll get back to u once i go check.
Old Apr 21, 2005 | 06:09 PM
tsjeff's Avatar
Default Re: does the jdm d15b vtec have this part? (dnoredsi)
thanks
Old Apr 22, 2005 | 04:19 PM
tsjeff's Avatar
bump, come on guys i need help here
Old Apr 24, 2005 | 02:12 PM
tsjeff's Avatar
ttt
Old Apr 24, 2005 | 02:36 PM
stormy's Avatar
you'll notice the tube goes into the IACV
The d15 does not have those ports. Or you can simply swap the tubes out easy enough
Old Apr 24, 2005 | 03:08 PM
tsjeff's Avatar
Default Re: does the jdm d15b vtec have this part? (stormy)
how would i go ahead and connect the vacuum hoses?
Old Apr 24, 2005 | 04:25 PM
slotec's Avatar
i think mine has those. only thing that didnt have was the evap(sp?) the sensor ont he backside of the intakemanifold that connects to the evap box.
Old Apr 24, 2005 | 04:26 PM
slotec's Avatar
Default Re: does the jdm d15b vtec have this part? (slotec)
and are u talking about the fillerneck
Old Apr 24, 2005 | 06:23 PM
stormy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9 3 d e l s o l &raquo;</TD></TR><TR><TD CLASS="quote">how would i go ahead and connect the vacuum hoses?</TD></TR></TABLE>
lol
those are coolant hoses and do it just as your old motor but either loop them or block them off with vacumm caps and some worm gears
Old Apr 24, 2005 | 06:29 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stormy &raquo;</TD></TR><TR><TD CLASS="quote">you'll notice the tube goes into the IACV
The d15 does not have those ports. Or you can simply swap the tubes out easy enough</TD></TR></TABLE> I hate to be the bearer of bad news but your somewhat wrong. Every and I mean EVERY honda has the IACV you mentioned. The tube actually goes to the FITV (Fast Idle Thermo Valve) It is a USDM obd1 thing. Prevents high or spurratic idle when the engine is cold.
Old Apr 24, 2005 | 06:32 PM
Bond's Avatar
Default Re: does the jdm d15b vtec have this part? (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote"> I hate to be the bearer of bad news but your somewhat wrong. Every and I mean EVERY honda has the IACV you mentioned. The tube actually goes to the FITV (Fast Idle Thermo Valve) It is a USDM obd1 thing. Prevents high or spurratic idle when the engine is cold. </TD></TR></TABLE>
x2 .
Old Apr 24, 2005 | 09:36 PM
tsjeff's Avatar
Default Re: does the jdm d15b vtec have this part? (Bond)
hmm.. so should the d15b have this? one of the tubes underneath the intake manifold has nowhere to go, so help me out guys.
Old Apr 24, 2005 | 09:43 PM
stormy's Avatar
lol
this is from a 00 b16
if you unscrew the two phillips screws and take off the nubs you'll have nearly every JDM version
Old Apr 25, 2005 | 11:24 AM
lol
if you unscrew the two phillips screws and take off the nubs you'll have nearly every JDM version</TD></TR></TABLE> This picture depicts the IACV the coolant line he points out goes to the FITV...
Old Apr 25, 2005 | 12:04 PM
NineTwoSi's Avatar
It has one with only one port... When I swapped my d15b in to replace my z6 I just used the one off of the z6 as well as the z6 intake mani... Now it's all good!
Old Apr 25, 2005 | 01:15 PM
Default Re: does the jdm d15b vtec have this part? (NineTwoSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NineTwoSi &raquo;</TD></TR><TR><TD CLASS="quote">It has one with only one port... When I swapped my d15b in to replace my z6 I just used the one off of the z6 as well as the z6 intake mani... Now it's all good! </TD></TR></TABLE>
Old Apr 25, 2005 | 03:01 PM
tsjeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote"> This picture depicts the IACV the coolant line he points out goes to the FITV...</TD></TR></TABLE>
I swapped the old d15b intake manifold out and put my z6 manifold in(for smog reasons). the first pic above that i circled shows that i dont have this nipple on the pipe. is there a way that i can go around this without swapping in another pipe from another motor?
Old Apr 25, 2005 | 03:17 PM
Tad's Avatar
Tad
some have that nipple some dont
my last d15b did not, my current one does..
I see no need for it though, and mine is currently plugged off..
on other honda engines it runs coolant to an oil cooler
Old Apr 25, 2005 | 03:50 PM
tsjeff's Avatar
Default Re: does the jdm d15b vtec have this part? (Tad)
thx for that reply. i needed to read something where i didnt have to spend money. so how would i go on and connect the nipple from the fitv?
Old Apr 26, 2005 | 11:05 AM
tsjeff's Avatar
ttt
ci_v_ic
24
Oct 18, 2024 07:01 PM
oldintegrao
Nov 14, 2009 07:21 PM
AnicDC2
Dec 26, 2005 09:52 PM
blo2k1
Jul 8, 2004 08:47 AM
VTEC ALLSTARS
22
Apr 25, 2003 05:41 PM
