who can install a turbo kit??????????
Old Apr 21, 2005 | 04:15 PM
vi3t0rious's Avatar
Default who can install a turbo kit??????????
sup..
does anyone know any company that can install a turbo kit? around the new england area????????????? mass? new hampshire? connecticut??
Old Apr 21, 2005 | 04:22 PM
b20vtechatch
Guest
Posts: n/a
Default Re: who can install a turbo kit?????????? (vi3t0rious)
me connecticut
Old Apr 21, 2005 | 08:06 PM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vi3t0rious &raquo;</TD></TR><TR><TD CLASS="quote">sup..
does anyone know any company that can install a turbo kit? around the new england area????????????? mass? new hampshire? connecticut??</TD></TR></TABLE>
Dude it isnt very hard. if you have a full weekend for your fist time, you should be good to go. I think the hardest part of installing a turbo is the feed line. Only because it is so cramped where you tap into the oil sending unit. I am going to use a oil filter sandwich deal so that will make the feed line 100 times easier. After that all you are really doing is installing an intake and a header and changing your feul injectors.
Old Apr 21, 2005 | 08:30 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: who can install a turbo kit?????????? (specv5150)
you should be able to do it yourself, its not really that hard.
HOWEVER, I DO SUGGEST YOU HAVE SOMEONE READILY AVAIABLE TO GIVE YOU ADVICE SHOULD YOU RUN INTO ANY PROBLEMS
Old Apr 21, 2005 | 08:48 PM
93turbo16's Avatar
Default Re: who can install a turbo kit?????????? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to do it yourself, its not really that hard.
HOWEVER, I DO SUGGEST YOU HAVE SOMEONE READILY AVAIABLE TO GIVE YOU ADVICE SHOULD YOU RUN INTO ANY PROBLEMS</TD></TR></TABLE>
And you will run into problems. Or we wouldn't have this forum.
Old Apr 21, 2005 | 10:40 PM
y0y0's Avatar
Default Re: who can install a turbo kit?????????? (93turbo16)
i ran into problems....turned out the labor was as much as the install would have been.
Old Apr 22, 2005 | 02:58 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: who can install a turbo kit?????????? (y0y0)
just research for a bit and do it yourself. you'll save some money and not to mention the learning experience thats involved.
hopefully this will be a good start:
https://honda-tech.com/zerothread?id=635014
gotzrycefoolio
May 29, 2005 07:34 PM
Fallen86
May 13, 2005 11:15 PM
princeperfect003
Jan 3, 2005 12:06 PM
smslude
Apr 27, 2003 01:48 AM
ITRfaithful
Jun 30, 2002 12:37 PM
