auto boost
Old Apr 5, 2005 | 09:13 AM
eymnewdc4's Avatar
Default auto boost
i know i know ..... get a 5 speed. i have a 95 LS integra with an auto tranny. i am not wanting to be the fastest guy out there or sink a ****-load of money into my car. but i would like a nice turbo set-up. clean looking, a little more power to the car, and just a little funner to drive.
i am thinking in the range of 6-7psi, no more.
the question really is this : i have talked to hondata and a few other places. nobody seems to make fuel management for automatics. how can i get around this or does anybody know what i can use for fuel management without totally ******* with wires and making it work properly. i want to properly tune the car with what will be done.
Old Apr 5, 2005 | 09:50 AM
ginoboy1978's Avatar
Default Re: auto boost (eymnewdc4)
Be careful, auto and turbo don't mix.......well actually auto TRANNY and turbo don't mix. Will be slipping like crazy.
Just giving you heads up.
Check out thread:
https://honda-tech.com/zerothread?id=1154822
Old Apr 5, 2005 | 03:43 PM
eymnewdc4's Avatar
Default Re: auto boost (ginoboy1978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ginoboy1978 &raquo;</TD></TR><TR><TD CLASS="quote">Be careful, auto and turbo don't mix.......well actually auto TRANNY and turbo don't mix. Will be slipping like crazy.
Check out thread:
https://honda-tech.com/zerothread?id=1154822</TD></TR></TABLE>
even at 6 psi?
Old Apr 5, 2005 | 04:07 PM
y7turbo's Avatar
just don't go to crazy on the trans like doing burnouts .. just don't beat the **** out of the trans and it should hold.. it also depends on how well your trans was taken care of before the turbo was installed..
mine holds 11psi just fine...
oh yeah only use honda atf when doing tranny fluid changes!!!
Old Apr 5, 2005 | 04:41 PM
ThaCivicAssassin's Avatar
Default Re: auto boost (konigturbocivic)
Doing the same turbo project..................93 lx and the trans will definitly be ok if you consider getting the rebuild performance kit. They run about 400...............Right now im piecing together a home made setup....U follow the research on here and U should be ok...As far as Fuel management some ppl on home made turbo ran a setup w/o a FM or injectors for that matter.............Don't let ppl tell U cant do it cuz its AT cuz it can be done and has been done........So jus follow up on yo ?'s and U'll be ok........Read my Tagline!!!
Old Apr 5, 2005 | 05:46 PM
Blanket Jackson's Avatar
K, I know this is like comparing apples to oranges, but I have an Eclipse Auto, and it seriously ****** kicks ***. It was N/T but I decided to DOHC and turbo it, big difference. There are people out there that make torque converters and shift kits for Honda AT's. Go with it, if ya feel like spending a lil more money making it reliable.
Old Apr 5, 2005 | 07:04 PM
kyden's Avatar
how many pinions are on the automatic carriers anyway?
Old Apr 5, 2005 | 07:09 PM
eymnewdc4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by konigturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">just don't go to crazy on the trans like doing burnouts .. just don't beat the **** out of the trans and it should hold.. it also depends on how well your trans was taken care of before the turbo was installed..
oh yeah only use honda atf when doing tranny fluid changes!!!</TD></TR></TABLE>
i dont even try to do burnouts or anything stupid. only hard thing i do is from time to time punch it. but its a little slow on acceleration anyway. but outside of that, i just gradually get to my highways speeds ....... 70+ (slowly) not romp on it and then stay there. i just want a little extra kick in my car. im not trying to beat anybody.
what turbo should i run? t25?
Old Apr 7, 2005 | 03:47 PM
y7turbo's Avatar
yeah the t25 is a great turbo for the automatic..
that was my first turbo. a dsm t25, it spooled up so fast.. it did kinda fall off at higher rpm but overall it was a great turbo for an automatic.
i now run a t3
Old Apr 21, 2005 | 02:31 PM
eymnewdc4's Avatar
what about superchargers?
i know they cost a bit more. but are they easier on an auto? im not looking to be the fastest, but i do wanna surprise some *************
Old Apr 21, 2005 | 02:57 PM
1bar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eymnewdc4 &raquo;</TD></TR><TR><TD CLASS="quote">what about superchargers?
i know they cost a bit more. but are they easier on an auto? im not looking to be the fastest, but i do wanna surprise some *************</TD></TR></TABLE>
A supercharger is still shovin air into your motor. Thus there is still a significant amount of stress on the trans.
Old Apr 21, 2005 | 02:58 PM
eymnewdc4's Avatar
Default Re: auto boost (1bar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar &raquo;</TD></TR><TR><TD CLASS="quote">A supercharger is still shovin air into your motor. Thus there is still a significant amount of stress on the trans. </TD></TR></TABLE>
between sc and turbo ... what is less stress? (until i can get a built auto tranny)
Old Apr 21, 2005 | 04:50 PM
s2kdre's Avatar
i had an auto with an sc61 and my tranny had 158k on it with no probs at 7psi as long as its not alot of power your tranny is not gonna slip. You just have to try it for yourself and see dont listen to anybody that has never had an ls auto turbo.
Old Apr 21, 2005 | 05:21 PM
raceACCORDingly's Avatar
i give you no more than 6 months before the clutch packs and bands start to go to **** and start slipping even w/ a tranny cooler.
my auto died after 1.5 yrs of light nitrous use. glad i converted to stick and going boost now.
Old Apr 21, 2005 | 05:31 PM
stinker504's Avatar
I have an 01 turbo accord for over a year now and I haven't had any problems. I run 6 daily and after 2nd gear I have the boost controller to turn it up to 9psi. Ohhh, don't forget to put a tranny cooler on. Helps out a lot.
Old Apr 21, 2005 | 05:40 PM
eymnewdc4's Avatar
Default Re: (stinker504)
stinker, jdmhonda ...... were both of you refering to turbo setups? or supercharger setups?
just want to be clear here.
Old Apr 21, 2005 | 05:46 PM
stinker504's Avatar
Turbo
Old Apr 21, 2005 | 06:03 PM
eymnewdc4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinker504 &raquo;</TD></TR><TR><TD CLASS="quote">Turbo</TD></TR></TABLE>
what turbo are you running or would you suggest for my auto 1.8 non-vtec
Old Apr 22, 2005 | 03:08 AM
stinker504's Avatar
I'm running a t3/t04e 57 trim .48 A/R. I like this size for my 2.3l. Nice spool times and enough power all the way to red line. But I would say something a little smaller for you. Possibly same turbo with a 50 trim. A T25 would also be great if you just want a little extra power. They are also easy to find for a much cheaper price.
JKov240
Honda Civic (2001 - 2005)
Apr 13, 2008 09:26 PM
dtown_racer
Sep 20, 2005 11:04 PM
jdm_tnr
Jul 13, 2005 10:04 AM
LSintegra
Apr 29, 2002 06:22 PM
Newbie In A Teg
Feb 20, 2002 11:10 PM
