Request : Oil Feed Line pictures and oil return pictures
Old Apr 21, 2005 | 03:20 PM
95BlkGSR's Avatar
Default Request : Oil Feed Line pictures and oil return pictures
i researched and found similar topics but the pics had all X out...so sorry for the repost kinda...
want pics of entire oil line setup...block to turbo, turbo to oil pan, and another line goes somewhere im not sure...jus need some pics to help me out...
i have a 95 gsr, t3/to4e turbo
thanks
Old Apr 22, 2005 | 06:24 AM
95BlkGSR's Avatar
Default Re: Request : Oil Feed Line pictures and oil return pictures (95BlkGSR)
any1?
Old Apr 22, 2005 | 06:38 AM
White Smoke's Avatar
i my honda
Global Mod
Dude there are plenty of pic links out there that still work.
Check out full-race oil line info: PDF
Here is another link that will help you. Scroll down to "TIP: How to do you oil lines"
Old Apr 22, 2005 | 11:09 AM
95BlkGSR's Avatar
Default Re: Request : Oil Feed Line pictures and oil return pictures (White Smoke)
thanks for the info man...any1 got anything to help me out?
Old Apr 22, 2005 | 08:32 PM
95BlkGSR's Avatar
common need some pics
Old Apr 23, 2005 | 10:52 AM
95BlkGSR's Avatar
ttt
Old Apr 25, 2005 | 03:57 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95BlkGSR &raquo;</TD></TR><TR><TD CLASS="quote">common need some pics
I gave you dam good pics and if you want more then SEARCH!
There are plenty of non-dead pic links that work fine for me.
We are not here to spoon feed you.
Old Apr 25, 2005 | 06:28 AM
Frozen E's Avatar
H-T White Ops
oil feed goes from behind the block to top of turbo. OIl drain goes from bottom of turbo to oil pan. Use your immagination.
Old Apr 25, 2005 | 06:30 AM
95BlkGSR's Avatar
Default Re: (IslandSi)
i just dont know where it comes off the block...i think its by the oil filter not 100% sure...i dont wanna go pulling things out and it not be the right thing
Old Apr 25, 2005 | 06:33 AM
Frozen E's Avatar
H-T White Ops
you need extra parts to make that work. Do a search for "tunertoys adapter" or "golden eagle sandwich". There's no place on a motor where you can just thread a feed line into.
I have a strong vibe that you'll be back in here in a couple of months asking how to do a compression test on your motor because it smokes like crazy now and is burning a LOT of oil.
Old Apr 25, 2005 | 08:17 AM
turbosi03's Avatar
GSR doesn't have a place for oil feed? the b16 does... hmm I wondered why people needed those adaptors...
here you can see my hole 1" to the left of the oil filter..
here's the return line...
I know I murdered the fittings with channel locks. this is a b16 but I felt bad no one else wanted to show pics...
good luck!
ps: your just adding a feed line, return line, and hopefully a line tapped from your feed source to the oil pressure gauge... thats it
Old Apr 25, 2005 | 01:21 PM
95BlkGSR's Avatar
Default Re: (turbosi03)
cant i just take out the il pressure sensor and put it there? and move the sensor to a side of a T ?
Old Apr 25, 2005 | 01:43 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">GSR doesn't have a place for oil feed? the b16 does... hmm I wondered why people needed those adaptors...
ps: your just adding a feed line, return line, and hopefully a line tapped from your feed source to the oil pressure gauge... thats it </TD></TR></TABLE>
He's still going to need some kind of adapter. The threads in the block are NOT NPT threads that every feed line I've ever seen needs. He's going to need some kind of an adapter.
Old Apr 25, 2005 | 01:44 PM
Frozen E's Avatar
H-T White Ops
Default Re: (95BlkGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95BlkGSR &raquo;</TD></TR><TR><TD CLASS="quote">cant i just take out the il pressure sensor and put it there? and move the sensor to a side of a T ?</TD></TR></TABLE>
Which is something you would have been able to answer had you searched for that Tunertoys(z) fitting like I told you to.
Old Apr 25, 2005 | 01:57 PM
nonvtecD's Avatar
Here's my oil return
Old Apr 25, 2005 | 02:11 PM
platinum00's Avatar
Default Re: Request : Oil Feed Line pictures and oil return pictures (nonvtecD)
Old Apr 25, 2005 | 06:35 PM
95BlkGSR's Avatar
Default Re: Request : Oil Feed Line pictures and oil return pictures (platinum00)
short oil return...i got 3ft of -10 an SS Hose...guess i need like 5 inches...lol
Old Apr 25, 2005 | 06:47 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
use oil resistant hose for return line. some performance shops will have such lines, or industrial type places, even plumbing will have red multi-purpose hoses that are oil resistant
Old Apr 25, 2005 | 07:06 PM
95BlkGSR's Avatar
Default Re: Request : Oil Feed Line pictures and oil return pictures (vtec.dc2)
already got the SS lines
LSTurbo23
Feb 14, 2010 05:00 PM
93turbotegSAV
Aug 29, 2006 02:44 PM
Hoosier Daddy
Jan 7, 2004 10:26 PM
NuclearB18B
Jul 31, 2003 02:02 AM
jdmciviceg
Mar 21, 2002 11:01 AM
