ITR 5-lug suspension swap onto EK/EJ Civic
Okay, from all the looking at various posts on honda-tech I think I have figured out most if not all of the parts I will need to do this swap on my '96 Civic 4 door. Keeping in mind that I have disc brakes up front and drums in the rear.
Parts list from an ITR:
Front hub/knuckle assembly (x2)
Rear trailing arm assemby (x2)
New brake lines (probably stainless steel at all 4 corners)
New brake pads (at all 4 corners)
5-lug rims
If its JDM then you need 36mm axles, if its USDM you need 32mm axles.
The rest of these parts I have seen in some posts but nothing has been an absolute must have, please correct me if I'm wrong. What car do I need all of the below mentioned parts from?:
Brake booster
Master Cylinder
40/40 Proportioning Valve
E-brake cables
Is there anything else that I may need?
5-lug rims
Brake booster
Master Cylinder
E-brake cables
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkwzt21 »</TD></TR><TR><TD CLASS="quote">
Brake booster
Master Cylinder
E-brake cables
Is there anything else that I may need?</TD></TR></TABLE>
All of the above from an EM1 Si. You can swap over LCAs but you will need ITR struts for the rear.
Brake booster
Master Cylinder
E-brake cables
djrico724
Suspension & Brakes
Jun 3, 2008 04:22 PM
Bone Stock
Dec 4, 2005 02:19 PM
enrique
Jul 21, 2003 11:22 AM
