does anyone else have this problem?
while the car is in idle if i put the clutch in, put her in first and get going, while in motion if i push the clutch back in and let go of the gas right away the revs drop so low (around 200-400rpm) that it seems as if she is about to stall and she's bogging like crazy. does anyone have this problem or is it just me? what do you guys think the problem is? thanks.
[Modified by caliItr, 5:23 AM 2/1/2002]
It happens sometimes with my car when I start the engine while it's still warm. It idles at 400 rpm for a while, but it doesn't stall....
mine also.
Will
while the car is in idle if i put the clutch in, put her in first and get going, while in motion if i push in the clutch back in and let go of the gas right away the revs drop so low (around 200-400rpm) that it seems as if she is about to stall and she's bogging like crazy. does anyone have this problem or is it just me? what do you guys think the problem is? thanks.
No i do not have cams. the only mods i have are; comptech icebox/intake, jun header, and carsound cat. can any of those mods be the problem? maybe its bad fuel? it usuall happens when i am in reverse.
reset your ecu, then start the car and let it sit at idle for 15min. don't touch the gas pedal. then turn the car off and take the key out. then put the key back in and start and drive the car around.
let us know the results.
