VTEC wiring in a 93 Dx
I'm swapping in a D15b this weekend and I don't have any wires/pins to do the wiring. I know what I need to wire, but I don't know what to use.
Will the car run without the Vtec wired up incase I don't get the right wires and pins by this weekend?
yes it run without vtec in
you will have a cel(wont rev over 3500 rpm)
as for wires go to radio shack get some 20gauge wires, solder, solder gun
no vtec doesn't throw you into limp mode, so you can rev past 3500, but don't rev into vtec rpm range. it won't really hurt anything, but your car will fall flat on its face, power wise. Vtec solenoid goes to A4, oil pressure switch D6, and oil pressure switch ground can just ground out the the head. BTW, since when do d15's have vtec? Is this a mini me?
fryman
Aug 6, 2008 11:21 AM
boosh
Jul 16, 2003 02:30 AM
