B18C1 rebuild help needed - thanks.
Hi guys,
Well this is my first post and I am in the process of buying a B18C1 for my 93 Civic.
1. We want to rebore it .20 over but will it need sleeves if I do .20 or is it still safe?
I am also changing the pistons, rods, bearing, rings with hi-perf. ones so that it can handle boost. Now I was told that I need low compression for a turbo or supercharger.
2. What compression ratio is good for turbo or supercharging on this motor?
3. What would be the best headgasket to use?
Thanks Guys - I heard honda-tech is the best. This is my first post hehe.
i dont think i would bore it that much then your bore/stroke ration will be way off. and yes you would want lower compression pistons in high boost applications. 9-1 to 9.5-1 would be good. and id use arp head studs and a cometic head gasket. but personaly id just keep stock bore and stock internals and use the head studs and a thicker head gasket to drop the compression a tad. then turbo on lower boost. unless you got alot of money then build the **** out of it.
Oh crap I am sorry (newbie error!), I mean't .020 (81.5mm) over. That is pretty safe isn't it? I mean I will it be safe without sleeves? I am gonna use a blockguard though. I heard the standard Honda headgasket is good enough - or does anyone know of a better one?
Now I also read on here of Wiseco pistons hitting the oil squirters in the block. I am planning on using SRP Pistons on my C1 - will these do the same also? Just thought I would ask here before I asked SRP
I plan on later boosting the C1.
Thanks alot guys - I really like this board and Honda-tech.com.
Modified by pcguy760 at 12:17 PM 4/22/2005
.I plan on later boosting the C1.
Sleeving your block would be good. But fully building your block would be the best and safest way. You want low compression liek around 9:1-9:2. High compression is for N/A. I would look into getting a Cometic Headgasket, and some ARP head studs.
Don't bore it unless you have to and then only .25mm over. I agree with the compression suggestions. What you use and how you build it has to do with budget and HP goals/useage.
joe pagolac
Aug 22, 2001 02:15 PM
