cant fix code 10?
Old Apr 21, 2005 | 12:00 AM
hookedonvtec's Avatar
Default cant fix code 10?
i recently baught a 94 EG dx. it has a swapped d16y6 out of a 95 del sol. the problem im having is that its throwing code ten(intake air temperature sensor). whats weird is the intake manifold has no plug for one. is there nething i can do to fix this? do i need a new intake manifold or what do i need to do? thanks guys
Old Apr 21, 2005 | 03:15 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: cant fix code 10? (hookedonvtec)
if it is obd1 or obd0 there should be a white plug on the intake, if not you may be able to run the wires to your cold air or short ram and use an obd2 IAT sensor.
Old Apr 21, 2005 | 02:48 PM
Default Re: cant fix code 10? (boostedcivicsir)
do i need the whole sensor? cause theres no plug on the intake, just a hole for what i would assume would be where the plug should be. how would i tell if its obd1 or obd0. im still learnin thanks for the input tho
Old Apr 21, 2005 | 03:59 PM
ttt
Old Apr 21, 2005 | 06:51 PM
uppppppp
Old Apr 21, 2005 | 07:19 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookedonvtec &raquo;</TD></TR><TR><TD CLASS="quote">do i need the whole sensor? cause theres no plug on the intake, just a hole for what i would assume would be where the plug should be. how would i tell if its obd1 or obd0. im still learnin thanks for the input tho </TD></TR></TABLE>
isnt the intake sensor only on obd2 cars????? What ecu do u have, is it the ecu from the del sol??
TRY UNPLUGGING THE BATTERY N ECU FOR 20 MIN, THIS SHOULD RESET IT!!!
Old Apr 21, 2005 | 07:57 PM
LilChuck's Avatar
Default Re: cant fix code 10? (CoupeVtec2k)
If there is a hole where one should be then goto a junk yard, get it, and wire it up. Or am I miss understanding something?
~Chuck
Old Apr 21, 2005 | 08:41 PM
Default Re: cant fix code 10? (LilChuck)
well theres no plug coming out of the wiring harness for it. i dunno where to splice it into either. im using a p28 ecu. im pretty sure thats what it was.
Old Apr 22, 2005 | 01:00 AM
up up
Old Apr 22, 2005 | 08:04 AM
EJ8VTEC's Avatar
Mr. Indecisive
like i said try resetting the ecu unplug that n battery for 20 min
Old Apr 22, 2005 | 08:57 AM
wilsel's Avatar
Is there an actual sensor on the manifold?
Old Apr 22, 2005 | 11:44 AM
Default Re: cant fix code 10? (wilsel)
nope theres no sensor on the IM
Old Apr 22, 2005 | 12:04 PM
wilsel's Avatar
so there is a hole there? car should be running really shitty without it. Do you know what a IAT sensor looks like?
Old Apr 22, 2005 | 12:05 PM
wilsel's Avatar
You car should have came with one, and so should the engine your using.
Old Apr 22, 2005 | 07:18 PM
FOMULA91's Avatar
I also have a problem with code 10 and it is running very shitty.
Old Apr 22, 2005 | 08:01 PM
Default Re: cant fix code 10? (FOMULA91)
yea it doesnt run to great. i actually found the sensor and its plugged in. dunno y i missed it before. anyone know what other reason it could be? should i replace the sensor?
Old Apr 22, 2005 | 08:36 PM
FOMULA91's Avatar
I found out that the TA sensor is causing the problem but my TA sensor conniction was covered with some kind of glue WTF???
Did you have problems when you start in 1st & 2nd gear because my acceleration is very crappy when I start out but it runs fine when I shift to 3rd, 4th, and 5th.
Old Apr 23, 2005 | 01:05 AM
i dunno where it is
RVMIRXZem1
Oct 25, 2018 07:43 PM
dohc_profile
Jul 5, 2008 09:26 AM
CRX MASE
12
Sep 25, 2006 07:42 PM
SiRLudeVtec
Apr 28, 2005 04:48 PM
EF4lyfe
Sep 20, 2004 12:00 PM
