HELP ASAP!!!
Old Apr 20, 2005 | 09:05 PM
t0ekn3e's Avatar
Default HELP ASAP!!!
just right now i was driving on the freeway and my corner flew off and now my signal lights dont work, also my intrument panel doesnt work none of the guages work but it lights up
Old Apr 20, 2005 | 09:08 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: HELP ASAP!!! (t0ekn3e)
perhaps when your corner flew off it ripped the bulb out with it? Causing the whole system to short. You prolly blew a fuse.
Old Apr 20, 2005 | 09:10 PM
t0ekn3e's Avatar
i checked all the fuses only the reverse went out
Old Apr 20, 2005 | 09:11 PM
H-T Poker champion
Default Re: (t0ekn3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">i checked all the fuses only the reverse went out</TD></TR></TABLE>
did you replace it? one fuse can cause the whole system problems..
your headlights still work, right?
Old Apr 20, 2005 | 09:14 PM
t0ekn3e's Avatar
yea my headlight still works all the stores are close i cant replace the fuse yet
Old Apr 20, 2005 | 09:18 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">
Old Apr 20, 2005 | 09:20 PM
t0ekn3e's Avatar
ill let youguys know in the morning
Old Apr 20, 2005 | 09:53 PM
allmotorEG-SI's Avatar
i think all those lights are connected, replace that and you should be fine.
Old Apr 20, 2005 | 10:04 PM
t0ekn3e's Avatar
what about the guage needles? cuz they dont work and i gotta drive 2 hours on the road to go home
Old Apr 20, 2005 | 11:08 PM
GdmLaz's Avatar
thats a fuse that makes all of it work 2gether i have blown it be4 check your fuses again im 100% fuse u most have missed it
Old Apr 21, 2005 | 11:53 AM
t0ekn3e's Avatar
so i replaced the reverse light fuse and everythign works now but it killed my stereo imma have to check that out now
Old Apr 21, 2005 | 04:45 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">so i replaced the reverse light fuse and everythign works now but it killed my stereo imma have to check that out now</TD></TR></TABLE>
Try unplugging the battery n ecu for 20min, then plug it back in
Old Apr 21, 2005 | 05:37 PM
H-T Poker champion
Default Re: (CoupeVtec2k)
you're welcome..
Old Apr 22, 2005 | 03:33 PM
t0ekn3e's Avatar
yay everythign works now thanks alot every one
sle.simon
Dec 14, 2006 04:04 PM
code47mastermind
Nov 15, 2006 06:05 PM
thinknology
Mar 31, 2005 08:58 PM
pLaTiNuM_pLuS_cRx
Oct 21, 2004 05:50 AM
99fbpem1
23
May 18, 2003 02:54 PM
