richmond gear spool and speedo gear
Old Apr 20, 2005 | 07:55 PM
TriK's Avatar
Default richmond gear spool and speedo gear
hi! today i install a spool from richmond gear in a Sir tranny .. i pressfit the speedo gear like it was on the original diff and i install the bearing after... when i install the spool in the casing, the speedo gear was rubing the casing and the bearing was not all the way down...
after measuring whats wrong with this.. i found where the speed gear are suposed to be are not enough large so the speedo gear are a bit to high so rubbing..
i had to cut 0.7mm of the gear on the milling and than it was perfect...
did you ever see this? i am using regular bearing with snap-ring shim.. not taper bearing
Emeraldbomber
Transmission & Drivetrain
Apr 29, 2014 01:00 PM
paopao
Jun 14, 2010 10:40 AM
gray_civic_coupe
Sep 16, 2005 01:15 PM
