People Running Thicker HeadGaskets: Chime In!!
What Motor were you running it on? Stock / Fully Built Etc.....
How thick of a head gasket were you using? Brand?
What Turbo Setup, Manifold Etc.... ?
How much power at the end did it make at what boost level? After tuning and getting it running cherry.
Thanks In Advance..
Thanks In Advance..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">What Motor were you running it on? Stock / Fully Built Etc.....
Thanks In Advance..
stock B18C
Cometic MLS
ARP Head Studs
Our turbo kit T3/TO4E .57 trim .63a/r
300/202 @ 9 psi
Thanks In Advance..
</TD></TR></TABLE>stock B18C
Cometic MLS
ARP Head Studs
300/202 @ 9 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com »</TD></TR><TR><TD CLASS="quote">
stock B18C
Cometic MLS
ARP Head Studs
300/202 @ 9 psi</TD></TR></TABLE>
how thick of a HG ?
stock B18C
Cometic MLS
ARP Head Studs
how thick of a HG ?
im running a double head gasket on a stock b16/60-1 turbo/ drag manifold car seen 18 plus pounds drives everyday at 8-9 pounds dyno'd once at 8 psi untuned 240 whp@8200 180 trq
my compression ratio, is going to be about 9.5:1 or 9.8:1 depending on which head i go with. this will be a highly built motor, with sleeves and all the good stuff and will be boosting a ton. should i get a thicker head gasket to lower cr a little, or do you think with the right tune itll be fine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">Nobody is answering your question because they are out in the garage installing their 5" DPs and exhausts.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodohcsi »</TD></TR><TR><TD CLASS="quote">my compression ratio, is going to be about 9.5:1 or 9.8:1 depending on which head i go with. this will be a highly built motor, with sleeves and all the good stuff and will be boosting a ton. should i get a thicker head gasket to lower cr a little, or do you think with the right tune itll be fine?</TD></TR></TABLE>
no need to get a thicker HG in your case. just get a really good tune..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">why would you want a thicker headgasket? how much is your current compression ratio?</TD></TR></TABLE>
to lower compression so that i can run more boost.
current compression is like 10.2-10.4, with the HG i got, its gonna be around 9.1-9.2:1
that must be a pretty thick headgasket you got there to lower the compression that much.
i think i recall reading somewhere that the thicker the gasket is there is greater chance of it failing
how about pulling the head off and doing some combustion chamber re-shaping to help lower the compression a little?
personally i wouldn't have any problems running 10:1CR and boost just as long as the pistons are forged.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">how thick of a HG ?</TD></TR></TABLE>
.045
.045
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">that must be a pretty thick headgasket you got there to lower the compression that much.
inline pro that specailizes in thicker headgaskets have ones bigger than the ones i purchased. I got the .074 from cometic and inline pro sells a 2mm and 3mm version.
from what i herd BEFORE that there are people making well into the 400+whp on stock motors with just thicker HG's.
What im worried too is the headgasket blowing out also. but we will see once its on the dyno.
</TD></TR></TABLE>inline pro that specailizes in thicker headgaskets have ones bigger than the ones i purchased. I got the .074 from cometic and inline pro sells a 2mm and 3mm version.
