tranny swap question
Old Apr 20, 2005 | 01:55 PM
rey98civic's Avatar
Default tranny swap question
What up everyone?
Here is my question to you: I just recently did a tranny conversion on my 98 ex I went fron auto to manual. Anyway everything works fine except my reverse lights they dont work. I checked all the fuses everything is o.k. So now I"m here asking the pros for help.
Old Apr 21, 2005 | 08:30 AM
rey98civic's Avatar
Default Re: tranny swap question (rey98civic)
anybody?
Old Apr 21, 2005 | 08:44 AM
spoonek9's Avatar
Is the switch hooked up and in working order, #11?
Old Apr 21, 2005 | 08:58 AM
BauleyCivic's Avatar
Risky Business
Default Re: tranny swap question (spoonek9)
There might be some wiring involved with that...but it's the back-up light switch. I'm not sure if the automatics are wired differently than the 5 speeds.
Old Apr 21, 2005 | 09:04 AM
FOC-US2K's Avatar
Default Re: tranny swap question (BauleyCivic)
to get the reverse lights working you have to run 2 wires from the harness that used to go to the auto shifter. one is yellow and the other is green I will double check in my car when I get home send me a pm to remind me. they go to the same color wires on the ecu harness that went to the auto part of the ecu. In the engine bay you should have plugs left over from the auto valve body's there is a plug there with a corresponding yellow and green wire in it that used to go to the valve body ontop of the auto trans. plug that into you manual rev switch and done.
Old Apr 21, 2005 | 09:05 AM
Risky Business
Default Re: tranny swap question (FOC-US 2K)
^ Thanks for the clarification
Old Apr 21, 2005 | 09:15 AM
rey98civic's Avatar
I said god daimn, thanks yall!!
Old Apr 22, 2005 | 07:32 AM
rey98civic's Avatar
any info on the color codes for the wire harness?
Killercocopuff
Oct 17, 2011 07:55 AM
bonjoey
Jun 8, 2011 04:18 AM
civic_ceze
Honda Civic (2001 - 2005)
Nov 2, 2009 06:55 PM
mengy007
May 10, 2006 08:10 AM
hatchbackhonda
Nov 16, 2004 04:52 PM
