Benifit of using jdm type r trailing arms vs 1995 gsr trailing arms on 5 lug conversion?
The benefits are:
1. type R has stiffer bushings
2. you don't have to do the work of transferring type R rear hub and brakes to
GSR trailing arm
3. I believe Honda designed in different compliance so that type R trailing arms
behave differently in compression to enhance handling. It's either that
or the extra 5mm of track in the rear.
I'm not sure if the stampings are the same since Honda has different part # for the
arms (probably because of the bushings).
GSR trailing arm
mofo951
Suspension & Brakes
Mar 22, 2012 03:31 PM
k20z
Feb 23, 2005 11:19 PM
743power
Dec 8, 2003 01:30 PM
